August 19, 2025, 08:17:50 PM *
Author Topic: LED hyper flashing  (Read 1628 times)
baldo
Youbetcha
Cape Cod, MA
« on: September 02, 2020, 07:29:22 AM »
I've replaced all my lights with LED's and have the hyper flashing problem. I've been through more than a few past threads about it, but haven't been able to find a link to an actual plug in replacement. I may have just missed it, but I've been looking. Our flasher unit is a 3-pin, I found a few units that looked like it would plug in, but only has two wires. I called SuperBrightLEDs, they weren't much help.
Does anyone have a solution? I'd really rather not cut into the harness.
« Reply #1 on: September 02, 2020, 07:41:11 AM »
The cheap two-pin (yes two pin, believe it or not) flashers you can find on eBay work perfectly.  I have installed them in several Hondas, a Shadow and three Valks.
This is the type I've used.
https://www.ebay.com/itm/222242213074
I have a brand new one in the garage if you don't want to ship from China.  Not looking to profit from it.
« Last Edit: September 02, 2020, 07:52:04 AM by Valkorado » Logged
baldo
Youbetcha
Cape Cod, MA
« Reply #2 on: September 02, 2020, 07:57:36 AM »
I suspected as much, the guy I spoke with said it wouldn't work, there are only two wires. Nothing more than that.
I think my local shop has them in stock. I'll check it out and will get back to you either way.
Thank you for the offer.
« Reply #3 on: September 02, 2020, 08:03:35 AM »
You're riding an IS, right?  If so that should be all you need.  If you're installing for a Standard or Tour, you'll also need one of these
https://www.kuryakyn.com/products/719/diode-kit
inside the headlight bucket.
I should say you may need the diode.  My Silver Bullet's setup did, it has switchback (cool white to amber) LED bulbs up front.   They just would not work properly with the flasher alone.  With the diode they work flawlessly.
« Last Edit: September 02, 2020, 02:56:46 PM by Valkorado » Logged
Foozle
Lexington, KY, USA
« Reply #4 on: September 02, 2020, 08:07:28 AM »
09-02
Bob:
There's two ways to accomplish this:  load equalizers or replacing the OEM flasher relay.  IMHO, the latter is a far simpler, more elegant, and more reliable solution.
I'm pretty sure this is the unit (below) I've used on my two Valks with front/rear LED signals:
https://www.customdynamics.com/standard-flasher-relay?cat=59
It's a direct plug-and-play replacement for the OEM - no cutting or splicing required.  The unit itself is located under the seat (behind the center panel) and is best accessed via the left side cover.  I don't recall if I had to temporarily remove the coolant overflow tank or not - but it's an easy swap.
Terry
baldo
Youbetcha
Cape Cod, MA
« Reply #5 on: September 02, 2020, 08:55:03 AM »
No, I've got a Std/Tourer. I'd forgotten about this. I just ordered one.
Thanks again,
Bob
baldo
Youbetcha
Cape Cod, MA
« Reply #6 on: September 02, 2020, 08:56:53 AM »
09-02
Bob:
Terry
That looks like the fix......and yes, it is behind the left cover. I pulled it yesterday to see the pin configuration.
Thanks.
Gondul
VRCC #408
Central Florida
« Reply #7 on: September 02, 2020, 11:01:53 AM »
That is stupid expensive for a diode...they must have kept them near the Hardly Drives stuff...
Diode and Flasher from from SuperBrightLEDs and much more reasonably priced...
https://www.superbrightleds.com/moreinfo/flashers-load-resistors/metric-bike-diode-kit/1190/2805/
https://www.superbrightleds.com/moreinfo/flashers-load-resistors/electronic-led-flasher-relays-for-motorcycle/787/842/
« Last Edit: September 02, 2020, 11:06:35 AM by Gondul » Logged
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
Gnarly
FlyinJenni2
Resume Speed,KY
« Reply #8 on: September 02, 2020, 11:09:52 AM »
Would like to add: the two-wire flasher from superbrightleds works great for the I/S, and it's under $10.
Edited to say: Oops. He doesn't need a  flasher for I/S.
I've loved many bikes, over the last 52 years of riding, but this Valkyrie machine may have propelled me headlong into IDOLATRY....
SCain
Rio Rancho, NM
« Reply #9 on: September 02, 2020, 12:01:22 PM »
The Show Chrome 13-306 LED Digital Flasher is a direct fit, plug it in and you are done.
$23.25 on Amazon
Steve
baldo
Youbetcha
Cape Cod, MA
« Reply #10 on: September 10, 2020, 12:21:45 PM »
Update:
The two pin contraption you see everywhere appears to work like a champ. I bought the diode setup, but haven't installed it yet.
Question: I installed colored LED's for brakes and turns, thinking it might be better than whites behind colored lenses. I'm still going with the original lenses. I haven't gotten the bike back together yet, so I can't say if it works or not. Thoughts?
Last thing...license plate light. OEM is a 67 bulb. It's a bit confusing trying to find an LED replacement. And why did Honda make you basically remove the fender to change a light bulb?
« Reply #11 on: September 10, 2020, 04:58:53 PM »
Update:
Last thing...license plate light. OEM is a 67 bulb. It's a bit confusing trying to find an LED replaceiment. And why did Honda make you basically remove the fender to change a light bulb?
On my Bullet, I installed switchback LED 1157s up front and clear lenses all around.  They are bright cool white when running, and amber when "flashing".  The cool white matches the color of my headlight and the runners in my Cobra Light bars.  Very cool effect, and attention getting -- when the whole front end is bright cool white except for the one flashing amber it's really easy for oncomers to see my intention.
All that said, the switchbacks would not function properly without the diode inside the headlight bucket.  They would stay amber, hyoerfiash, etc.  Even with the flasher.  The diode fixed that.
« Last Edit: September 10, 2020, 05:06:23 PM by Valkorado » Logged
Gondul
VRCC #408
Central Florida
« Reply #12 on: September 10, 2020, 05:33:44 PM »
I used colored bulbs behind the colored lenses and they are very bright red/yellow...when I asked SuperBrightLEDs they said they very bright white color from the LED can 'washout' the colored lenses and recommends colored bulbs...
I didn't bother with the license plate light... I'll replace it when it blows out...
John Adams - 1797
Jims99
Ormond Beach Fl.
« Reply #13 on: September 11, 2020, 04:52:42 AM »
+1. I did same on mine.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
crow
Toujours Pret
Citrus Co Fla
« Reply #14 on: September 11, 2020, 09:16:08 AM »
Not exactly  on topic, but I found on line, a  red laser product  for rear brakes.  It projects  a SUPER bright  display  of several choices of patterns like spider web, x's and o's etc, or a straight beam     on the road behind you. Don't know  if its legal  being a laser, but showes in the fog like nothing  I've ever seen.
that your ass cant cash
