November 13, 2025, 04:54:23 AM *
Author Topic: Sheetmetal screws in the exhaust?  (Read 1228 times)
« on: September 03, 2020, 04:14:03 PM »
Is there a reason someone would drive sheetmetal screws partially into a modified OEM exhaust? Crawling around under my new to me 1999 Interstate, and just behind the headers on both sides there are what appear to be sheet metal screws driven partially into the canister....
Any idea what that would have been done for???
« Reply #1 on: September 03, 2020, 04:22:07 PM »
take them out. that is the condensate drain so the internals do not rot out.  previous owner just didn't know any better.
« Reply #2 on: September 03, 2020, 04:31:52 PM »
Take 'em out periodically to let it drain, or take 'em out and leave 'em out?
« Reply #3 on: September 03, 2020, 04:37:17 PM »
Leave them out
« Reply #4 on: September 03, 2020, 06:21:16 PM »
Leave them out
Done. And glad I did, they were only 2 or so turns in, that was just ASKING to fall out and end up in my rear tire on a Sunday hundreds of miles from nowhere!
Thanks!
« Reply #5 on: September 03, 2020, 06:40:24 PM »
Leave them out
Thanks!
It is amazing what some owners will do. He probably saw some condensation drip out, and figured "I better plug that up". I remember Hook talking about a bike he bought that had the side panels put on with drywall screws. (At least that's how I remember the story) It sounds like you are going over everything pretty good already. But wouldn't be a bad idea to replace antifreeze, check any wiring mods, etc.
« Reply #6 on: September 03, 2020, 06:55:44 PM »
Leave them out
Thanks!
Yeah, and the PO used wood screws and epoxy to hold the I/S headlight assembly together.  Not even good wood screws.  He used flat heads.
He couldn't figure out the spring clips.
I gotta admit, I thought I knew more than Honda Engineers when I removed the "T" from the tank vent/drain hose.  Learned what that was about at the first rain storm I hit.
« Reply #7 on: September 03, 2020, 07:02:14 PM »
Leave them out
Thanks!
Grin (you wouldn't be the first)
