August 19, 2025, 05:54:24 PM *
Author Topic: Add on Fuse box wiring  (Read 1350 times)
jmint
Willow Spring, NC
« on: September 06, 2020, 06:06:56 AM »
I would really like to add an additional fuse box like the eastern beaver PC-8, but I'm no electrician.  Do I only need to get the PC-8 box and that will come with everything I need, or do I need to also get the powerlink relay or some other relay kit offered?
I'd like to add a dedicated circuit for phone charging along with a bluetooth dongle to pass phone audio through the IS speakers.  I'm also wanting to add heated gear this winter and I'm planning to purchase jacket, pants, gloves and socks (though maybe just the jacket and gloves to begin with and add the pants and socks later if necessary).  No other electrical add on plans at this point.
« Reply #1 on: September 06, 2020, 07:58:34 AM »
You need the relay and wiring setup. (Or make up your own)
« Reply #2 on: September 06, 2020, 08:27:29 AM »
                  NO help on the lectrical stuff BUT I like the name of yer town!  cooldude RIDE SAFE.
« Reply #3 on: September 06, 2020, 08:28:10 AM »
I just installed my third Eastern Beaver PC-8 setup, this one in my new to me 99 Interstate, and I too am no electrician, but was able to get this done pretty easily.
I went with the "PC-8 and 50A Relay Kit" with an 18" lead.
https://easternbeaver.com/Main/Wiring_Kits/Fuseboxes/PC-8/body_pc-8.html#30Akits
It seems complicated at first, but the wires line up making it pretty obvious once you go through the directions and get going.
https://easternbeaver.com/Main/Wiring_Kits/Fuseboxes/PC-8/Installation/installation.html
jmint
Willow Spring, NC
« Reply #4 on: September 06, 2020, 08:51:32 AM »
Serk, where did you end up putting your PC-8?  I'm thinking behind the right side cover.  M6 ring terminals?
« Last Edit: September 06, 2020, 08:53:59 AM by jmint » Logged
« Reply #5 on: September 06, 2020, 11:35:27 AM »
I tucked it into the compartment behind the battery where I think the OEM tool kit and owner's manual went...
A side panel installation would probably be a little cleaner (Be sure to measure the distance and order the right length of leads to reach the destination you want to use!)
The M6 ring terminals are just metal rings that go over the battery posts...
« Reply #6 on: September 06, 2020, 11:54:30 AM »
The problem with the install under the right cover is that it will block access to some important stuff. Unless one puts it on a hinge like MarkT did.
jmint
Willow Spring, NC
« Reply #7 on: September 06, 2020, 01:18:05 PM »
10-4 on all that, much appreciated.
Gondul
VRCC #408
Central Florida
« Reply #8 on: September 06, 2020, 02:42:48 PM »
I just redid all the wiring on my bike... I also went with the PC8, put the relays in the box under seat and the PC8 sitting right on top...plenty of room
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
Itinifni
Boston
« Reply #9 on: September 07, 2020, 09:55:54 AM »
I posted some details and photos of my PC8 install a few years ago.
http://www.valkyrieforum.com/bbs/index.php/topic,90482.msg893212.html#msg893212
A few others added photos of their installs so you can get a few ideas.
Hope it helps.
73? CT70
79 CB750K
82 GL1100
94 CBR1000F
Kid
Kid
97 Valkyrie Std. (May surpass the GL1100 as the best bike I've ever owned, I'll update in 50k miles)
Gnarly
FlyinJenni2
Resume Speed,KY
« Reply #10 on: September 11, 2020, 02:32:05 PM »
Me,too! What Gondul said.
And on the I/S, there's room behind the right inner fairing cover for another PC-8, for foglights, charger,heated gear,etc.
And plenty room behind the left inner fairing cover for an (admittedly) copycat relay setup to power two Marco Tornado horns.
Eastern Beaver makes nice stuff, and it's simple enough for non-electricians!
« Last Edit: September 11, 2020, 02:35:41 PM by Gnarly » Logged
I've loved many bikes, over the last 52 years of riding, but this Valkyrie machine may have propelled me headlong into IDOLATRY....
« Reply #11 on: September 12, 2020, 06:43:19 AM »
I have found that for electric heat, a long-sleeved jacket liner and glove liners are enough down to a few degrees below freezing, especially with long johns, jeans, and leather chaps on my legs.
I hate having a bunch of ring terminals on my battery posts, and prefer only having the single original connection on each post.  Instead, I draw power for my auxiliary fuse block from the bottom of the 55A fusible link (its black cover says "FUSE - FUSIBLE"), behind the right side cover.  IIRC, this required carving a little bit of plastic off to allow the connection.  I connect most of my added grounds through a ground bus connected to the screw that fastens the right end of the centre cover.  I used brass screws and anti-oxidant paste (not dielectric grease) to prevent corrosion.
You can barely see my red power wire behind the smaller red wire which powered my air horn compressor (now gone).  It goes from the bottom of the fusible link to the fuse block, located behind the battery.
