November 13, 2025, 04:53:45 AM *
Author Topic: Spiting and sputtering at higher rpms when warm  (Read 1468 times)
troy11533
Holts Summit, MO
« on: September 08, 2020, 09:01:46 AM »
So my bike has been spiting and sputtering at higher rpms when it’s been running at highway speeds for a couple of hours. It almost sounds like it’s starving for fuel but when I stop to get fuel for 10 minutes it’s fine then it does to same thing when ever it gets hot. NEED HELP!!!!!!!
« Reply #1 on: September 08, 2020, 10:50:55 AM »
oem petcock diaphragm might need replacement. it starts getting pinholes from wear movement.
or carbs are out of tune and adjustment.
« Last Edit: September 08, 2020, 01:52:24 PM by 98valk » Logged
yrunvs
Prior Lake, Minnesota
« Reply #2 on: September 08, 2020, 01:28:01 PM »
Could it be a heat related electronic issue. I'm new to Valks and (if they have one) a regulator/rectifier would act that way if on its way out.
I'm no gynecologist but hey I'll take a look!
pancho
Bonanza Arkansas
« Reply #3 on: September 08, 2020, 03:19:45 PM »
Sounds like a classic case of the fuel tank vent being pinched. Open the cap with a spare key when it happens and see if that clears it up.
Jims99
Ormond Beach Fl.
« Reply #4 on: September 09, 2020, 05:00:54 AM »
Sounds like it’s starving for fuel. Like mentioned, vacuum line or petcock, vent line or external fuel filter. Gas isn’t flowing fast enough to keep up with fuel demand at higher speeds.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
« Reply #5 on: September 09, 2020, 07:13:52 AM »
And put your head down there and listen for a sucking noise at opening of rubber seal.
In a pinch, you can close the cap on a zip tie (to add more venting).  But that's a temp fix.
Edvalk
Dayton Ohio
« Reply #6 on: September 09, 2020, 03:33:11 PM »
My standard was doing the same thing . OEM petcock was the culprit. Installed a pingle and no problems since.
1998 valkyrie standard , 2007 Suzuki Bandit 1250
