mello dude
Dayton Ohio
« on: September 30, 2020, 07:30:44 PM » |
Feels like I posted this before, but I cant find it. Anyhoo, I have adjustable brake levers like the pic on my VFR that I really like. I specifically like the adjust number wheel on it. I can change it in 2 seconds even while going down the road. Looking for one like it for the Valk... -- I thought someone said a GW is like that or any ideas? Thanks!
« Last Edit: October 09, 2020, 10:02:41 PM by mello dude »
* There's someone in my head, but it's not me....... * Mr. Murphy was an optimist.... * There's a very fine line between Insanity and Genius..... * My get up and go, must have got up and went.....
« Reply #1 on: September 30, 2020, 08:29:39 PM » |
I seem to recall there were (or used to be) two sources for wheel-adjustable levers for 1800 goldwings that could be adapted for valk. Here is an old post from the Delphi VRF forum on the subject, including cutting a tab off the clutch side lever. Be sure to read the addendum added to this link; when I used them, I ended up with a a sticky brake light situation (just like the poster did), where when I released the brake lever, the brake light stayed on for 3-4 more seconds every time. Had to dick around with the tension bolt to get it just right, not too tight or too lose. The links may no longer work. http://forums.delphiforums.com/valkyrie/messages/?msg=13360.1I had those levers on both my interstates, but over the years broke several of them, they are cast aluminum, and one good hit and they snap into pieces. And I never trusted them at the extremely close reach settings. The (nonadjustable) Kuryakyn wide chrome levers for Valk are far superior to the adjustable levers (and the skinny stock levers too), and have a bit of a shorter reach built into them than stock. And they don't have to be modified. Although with all Kuryakyn chrome parts, sometimes a bit of filing too-fat chrome is necessary. https://www.kuryakyn.com/products/3747/wide-style-levers
« Last Edit: September 30, 2020, 08:38:20 PM by Jess from VA »
« Reply #2 on: September 30, 2020, 09:03:48 PM » |
Kuryakin sells adjustable levers that fit. I bought just the brake lever from them through a local service shop.
ridingron
« Reply #3 on: September 30, 2020, 11:05:41 PM » |
part numbers?
mello dude
Dayton Ohio
« Reply #4 on: October 01, 2020, 04:32:20 AM » |
Interested in the Kuryakyn part numbers on this one. I can't find any on their website. Did a check on Partzilla, and apparently, OEM GL1800 has the thumb wheel adjusters.
« Last Edit: October 01, 2020, 04:40:10 AM by mello dude »
Bagger John - #3785
« Reply #5 on: October 01, 2020, 06:09:14 AM » |
Did a check on Partzilla, and apparently, OEM GL1800 has the thumb wheel adjusters. I'm running a set of black OEM GL1800 levers on my '01 I/S; this with the stock Valkyrie reservoirs. They were plug and play. No fiddling whatsoever required to make them work.
Ramie
« Reply #7 on: October 01, 2020, 10:48:00 AM » |
“I am not a courageous person by nature. I have simply discovered that, at certain key moments in this life, you must find courage in yourself, in order to move forward and live. It is like a muscle and it must be exercised, first a little, and then more and more. A deep breath and a leap.”
mello dude
Dayton Ohio
« Reply #8 on: October 01, 2020, 02:11:37 PM » |
Did a check on Partzilla, and apparently, OEM GL1800 has the thumb wheel adjusters. I'm running a set of black OEM GL1800 levers on my '01 I/S; this with the stock Valkyrie reservoirs. They were plug and play. No fiddling whatsoever required to make them work. I looked thru quite a few GL year model fische, and levers.. wondering now, are all years black? Hoping to find the OEM standard silver....
Bagger John - #3785
« Reply #9 on: October 01, 2020, 03:09:52 PM » |
Let me look through my old issues of Wing World and see if I can find an OEM silver set on a given bike. As I recall, all 1800 levers are black with the chrome adjustment knobs.
Gnarly
FlyinJenni2
Resume Speed,KY
« Reply #10 on: October 01, 2020, 03:32:53 PM » |
I used the silver adjustable ones from Show Chrome....$54. Best price I found was on evilBay: https://www.ebay.com/itm/254180382242Hope that helps!
I've loved many bikes, over the last 52 years of riding, but this Valkyrie machine may have propelled me headlong into IDOLATRY....
h13man
Indiana NW Central Flatlands
« Reply #11 on: October 02, 2020, 06:57:04 AM » |
Kury Wides and a VTX1800 clutch MC.
Bagger John - #3785
« Reply #12 on: October 02, 2020, 07:52:55 AM » |
The Kuryakyn adjustable wide levers (currently running a set on my Tourer) required filing, machining and fiddling, and even then I experience a slight amount of drag if the pivot hardware isn't well lubricated.
mello dude
Dayton Ohio
« Reply #13 on: October 02, 2020, 08:05:58 AM » |
Unless I find a Honda OEM silver solution, I am thinking to grab the GL1800 black levers. For the moment, I need plug and play.....my bank account for fiddling on this bike is presently empty. I'm having fun at the moment trying to get the front brakes to fully bleed.....
« Last Edit: October 09, 2020, 07:58:26 PM by mello dude »
Bagger John - #3785
« Reply #14 on: October 02, 2020, 12:31:33 PM » |
I looked at an online parts listing for the last model year Gold Wing - the 2000 Aspencade. It shows a brushed aluminum finish, non-adjustable lever like our Valkyries use.
Next, I headed to FleaBay and searched for "GL1500 levers". Of course, lots of Valkyrie listings - but those from the 'Wings are as noted above - brushed aluminum and non-adjustable.
May want to check the 'Bay for OEM GL1800 levers. I got my set for under $20, IIRC.
« Last Edit: October 07, 2020, 07:42:39 AM by Bagger John - #3785 »
mello dude
Dayton Ohio
« Reply #15 on: October 02, 2020, 12:47:32 PM » |
I looked at an online parts listing for the last model year Gold Wind - the 2000 Aspencade. It shows a brushed aluminum finish, non-adjustable lever like our Valkyries use.
John , thanks for your efforts..
Avanti
« Reply #17 on: October 02, 2020, 02:56:29 PM » |
You need to check the part number of each of the fasteners for these levers, I believe they are different.
mello dude
Dayton Ohio
« Reply #18 on: October 02, 2020, 09:20:25 PM » |
Those are interesting design Steve, the vendor is French. Not sure I want to go there....
-mike-
« Reply #19 on: October 02, 2020, 10:52:40 PM » |
... I had those levers on both my interstates, but over the years broke several of them, they are cast aluminum, and one good hit and they snap into pieces. And I never trusted them at the extremely close reach settings.
Thanks for keeping me off buying these! -mike-
mello dude
Dayton Ohio
« Reply #20 on: October 06, 2020, 12:59:07 PM » |
I'm gonna buy new GL1800 , so do I need the bearing bolts new to? Or can I reuse the Valk bolts/cap nuts?
Thxz
(Jeez, this Valk project is a money pit!)
Bagger John - #3785
« Reply #21 on: October 07, 2020, 07:46:47 AM » |
That's what I did with mine, as indicated above. "Plug and Play". (Jeez, this Valk project is a money pit!)
Remind me to show you receipts for my two.
KG
« Reply #22 on: October 09, 2020, 12:49:07 PM » |
Show chrome 18-111BC Got this part number from Bob at atticrat performance while I was at his shop.
You have to trim a small piece off the bottom of the clutch lever that is used to disengage the cruise on a gold wing. But you can’t see it when it’s installed
Also while they are off I would order new seals and push rods and the clutch lever bushing
What we do all have is a limited number of days to devote to whatever we love in this life. Not all the same number of days but all have limited days....Willow
« Reply #23 on: October 09, 2020, 07:53:19 PM » |
I've never thought of replacing the pushrod. They always seemed fine after cleaning them up. But definitely the rubber boots and the bushings.
mello dude
Dayton Ohio
« Reply #24 on: November 25, 2020, 11:18:23 AM » |
Thxz
Received the new GL1800 levers.....they are about an inch longer than the Valkyries. Not really wild about it, trying to decide whether to use them....
baldo
Youbetcha
Cape Cod, MA
« Reply #25 on: November 27, 2020, 02:09:45 PM » |
You beat me to it. Bob's putting them on mine....
Avanti
« Reply #26 on: November 27, 2020, 03:58:54 PM » |
Show chrome 18-111BC I did not like how loose the bushing fit to pivot pin was so I made new bushings for the levers.
mello dude
Dayton Ohio
« Reply #27 on: November 27, 2020, 10:50:03 PM » |
You beat me to it. Bob's putting them on mine.... Post up photos when you get it back.....
