February 12, 2026, 09:12:12 AM *
Author Topic: Interstate fuel tank  (Read 3552 times)
Broadway
« on: November 03, 2020, 06:51:38 PM »
So I bought an Interstate fuel tank for my 97 Standard. How do i plug the fuel sending unit hole? What has worked for you guys?
« Reply #1 on: November 03, 2020, 07:33:20 PM »
BigBF makes a plate for that purpose.
Bagger John - #3785
« Reply #2 on: November 04, 2020, 07:48:17 AM »
Search this forum for similar threads.
Plug the hole with an OEM I/S sending unit. Then wire in a fuel gauge. I detailed what I did for my Tourer in one of those threads.
« Reply #3 on: November 04, 2020, 08:17:09 AM »
pinwall has a used plate listed on ebay.
Mooskee
Southport NC
« Reply #4 on: November 04, 2020, 08:22:55 AM »
I have an old sensor unit that has been stripped leaving only the blank off plate. It's yours if you want it. You will need to buy a new O-ring. Message me with address if you want it.
« Reply #5 on: November 05, 2020, 10:17:35 PM »
A flat piece of 1/8" steel with appropriate holes and the right size O-ring will do it.  Simple & it works on my Deerslayer for about 20 years now.
Steel cowboy
Spring Hill, Fl.
« Reply #6 on: November 06, 2020, 05:21:18 AM »
Why not make it functional, only fuel sender and gauge needed.
2001 black interstate
2003 Jupiter Orange wing
« Reply #7 on: November 06, 2020, 05:50:07 AM »
I have a 2014 Valk with a gauge and also a 97. I like using my
trip meter and reserve as a gas gauge more than I like the
actual gauge on the 2014. Just got used to doing it that way,
I guess...
Bagger John - #3785
« Reply #8 on: November 06, 2020, 10:45:52 AM »
I guess...
Trip meters can accidentally be reset, can stick upon operation and so forth. A properly set up gauge can't.  Wink
« Reply #9 on: November 06, 2020, 04:16:52 PM »
Gauges can accidentally be overlooked, or short out and cause your bike to catch on
fire and so forth. Reserve reminds you if you forget to watch the trip meter   Cheesy
« Reply #10 on: November 07, 2020, 06:21:31 AM »
I have 9.6 gallon capacity with I/S & belly tanks on Jade.  Unless on a road trip, I always buy pure gas.  Try to run the tanks down low periodically.  When doing that I send the BT fuel up to the main when I have over 100 miles on the ticker.  Range is over 300 miles.  No fuel gauge, always use the odometer on refueling.  Never need to use the reserve - never get that low.  But it's there if needed.  I don't trust fuel gauges; they are never linear.  I use the odometer for fuel range on my cars too.
« Reply #11 on: November 07, 2020, 07:31:58 AM »
I guess...
why are u letting people touching your scoot and resetting your trip meter?
Bagger John - #3785
« Reply #12 on: November 07, 2020, 07:52:05 AM »
I guess...
Go wash and wax your bike. Let the towel spin the knob accidentally.
Or...as used to happen with my 2000 Tourer, occasionally the trip meter would hang at 99.9. Not a big deal with a larger tank or if you catch it soon into the ride, but a VERY big deal if you aren't paying close attention. My '99 will sometimes hang at 09.9 but that's rather insignificant.
As far as an earlier post concerning fuel gauge wiring: I haven't see that problem with the stock I/S fuel gauge and I certainly don't see a problem with a properly designed and installed aftermarket implementation of same. Mine's been on my '99 Tourer for 12 years sans issues.
Mike S.
High Point, NC
« Reply #13 on: November 11, 2021, 12:07:09 PM »
I know this is an old thread, I am still looking.
Does anyone know where I can get a known good fuel unit for a '99 Interstate?
I hope there is at least one out there!
Semper Fi!
There is no fair in fight, no cheat in win!
« Reply #14 on: November 11, 2021, 01:49:47 PM »
Call Pinwall Cycle in Ohio.  (unless you feel like sorting through a thousand pages of parts, which is never up to date with everything they may have)
https://pinwallcycle.com/
Mooskee
Southport NC
« Reply #15 on: November 11, 2021, 03:36:27 PM »
There are a couple on eBay for about $42 right now.
Mike S.
High Point, NC
« Reply #16 on: November 11, 2021, 07:11:41 PM »
Y'all are great - I'll check in the am - I did look at eBay and didn't see anything though. Maybe I am not using the right search name, I was looking for fuel unit by part number.
Semper Fi!
« Reply #17 on: November 11, 2021, 07:28:21 PM »
https://www.ebay.com/itm/274991675420?hash=item4006c7f81c:g:inAAAOSwFfhhbt6H
I think good descriptive words cast a wider search net than a part number.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=honda+1500+valkyrie+interstate+fuel+sending+unit&_sacat=0
Pinwall Cycle bike salvage has an Ebay store, but I always call and talk to a human for better service, and less wasted time.
« Last Edit: November 11, 2021, 07:31:37 PM by Jess from VA » Logged
Mike S.
High Point, NC
« Reply #18 on: November 12, 2021, 06:03:06 AM »
Thanks Jess, contacted the one seller, item looks good. Also found a handlebar clamp I need from same seller. Just waiting on replies concerning returns and combined shipping.
Thanks again!
Semper Fi!
« Reply #19 on: November 12, 2021, 06:15:03 AM »
Glad to help Mike.
I suck at auto electric, but I seem to recall reading that the interstate fuel sending unit works with the wires reversed from most all other vehicle/motorcycle sending units.
From a quarter tank down (on both my interstates), I rely more on my trip meter than my led bar fuel gauge.  It starts flashing (just) before reserve, and is no longer a gauge, just an annoying flashing light.
The moment I hit reserve (supposedly 1.1gal), I reset my #2 tripmeter to 0 and conservatively figure I have 30 miles to find gas.  (I also lighten up on the throttle, unless I know where the gas is.)
« Last Edit: November 12, 2021, 06:18:39 AM by Jess from VA » Logged
Mike S.
High Point, NC
« Reply #20 on: November 12, 2021, 08:17:18 AM »
I've not ridden mine in a couple of years, the last tag decal is likely 2016, being stored in the garage and not ridden was the demise of the tank I am sure. There was so much rust build up inside there was no fuel flow. The tank has had the rust removed, and coated (guaranteed for life of tank) but the sending unit is toast. Whether I ride it or not is up in the air, I need it functioning fully, no matter what direction I go.
Semper Fi!
Madmike
Campbell River BC, Canada
« Reply #21 on: November 12, 2021, 11:27:29 AM »
You can take the arm and float assy off the existing mount plate and just use that, 2 screws and you are done.  You can also get a gauge that will work with the OEM sender, VDO makes one,  part number is VDO 301-107, available from Amazon.
here is the Amazon.ca link
https://www.amazon.ca/gp/product/B00T9K9FWQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Mike S.
High Point, NC
« Reply #22 on: November 12, 2021, 12:51:18 PM »
Well, lost the really nice one by about 20 minutes making a deal for combined shipping. Should have just bought the silly thing straight out.  Angry
There is a rusty but functioning one also, I'm debating...
And no joy with Pinwall
Semper Fi!
amazngrace
Eastern Shore, Virginia
« Reply #23 on: December 29, 2021, 06:54:57 PM »
Made a cover plate out of aluminum. Cut square plate, drill 4 holes, bolt to tank with new O ring (Honda 91305-MC7-000), ALL DONE!
ED  cooldude
99 Red and Black IS
