December 30, 2025, 06:54:34 AM *
Author Topic: Switching Standard throttle assembly to I/S throttle assembly  (Read 1168 times)
« on: January 02, 2021, 11:00:47 AM »
Any one know if this is just a swap or are new cables needed?
Also wondering if the electrical plug is compatible?
baldo
Youbetcha
Cape Cod, MA
« Reply #1 on: January 02, 2021, 11:20:29 AM »
Cables are the same as far as I know
Attic Rat just changed my right switch housing out and didn't say anything about replacing the cables. I went with the I/S assembly because the cables route out the bottom of the housing. This provides the extra cable length needed if you want to go with taller risers.
I believe the electrics are the same.
« Reply #2 on: January 02, 2021, 11:27:31 AM »
Hey Bob, thanks for the info.
How you doing?
I need to move the position of where the cables come out from the assembly cause they interfere with the mirror stem, making the mirror useless and the brake lever somewhat to high.
I don't care about the mirror, except the blinker is in it, so it stays.
I can see the cables are different at the ends that attach to the assembly, cause the angle on them is different.  Just wondering if compatible.
What did Attic Rat do to your bike?
« Reply #3 on: January 02, 2021, 11:38:17 AM »
Bill, it will be no problem. I have used Standard cables on my I/S before.
« Reply #4 on: January 02, 2021, 11:41:52 AM »
Thanks Rob,  I kinda thought that but figured I'd ask here.
You tired of being retarded  retired yet?
« Reply #5 on: January 02, 2021, 11:43:25 AM »
Grin nope, liking it pretty well.  cooldude
« Reply #6 on: January 02, 2021, 11:45:56 AM »
Good for you. Smiley
Happy New Year Brother.
Say "Hey" to Brenda for me
« Reply #7 on: January 02, 2021, 11:56:50 AM »
You too. Thanks  cooldude
