December 30, 2025, 06:54:34 AM
Fork leg “special” washer question
Topic: Fork leg “special” washer question (Read 1258 times)
FLAVALK
Winter Springs, Florida
January 08, 2021, 01:10:50 PM »
Is there anything magical about the 8mm crush washer (90544-283-000) used in both fork legs, or will any 8mm crush washer work so long as the ID and OD are the same?
Correction, thanks to my Hubcap friend, used in one leg.
Last Edit: January 08, 2021, 05:01:13 PM by FLAVALK
Re: Fork leg “special” washer question
January 08, 2021, 04:34:26 PM »
It might be special that it is only used in one of the fork legs
I did my forks a year ago (dang, time flies!) and I used a honda one...
FLAVALK
January 08, 2021, 04:58:54 PM »
Quote from: hubcapsc on January 08, 2021, 04:34:26 PM
Well, you are right about that. The left leg doesn’t have the damper, so....
The question still remains. Like most OEM parts, this thing is overpriced.
January 08, 2021, 05:19:06 PM »
Yeah, it looks just like a copper crush washer to me, I guess it
might need to be some particular thickness? I don't have the
expertise to offer an authoritative opinion. I've gotten little bags
of assorted copper crush washers at Advance Auto though...
h13man
Indiana NW Central Flatlands
January 09, 2021, 06:41:59 AM »
Quote from: FLAVALK on January 08, 2021, 01:10:50 PM
If my memory serves me right, the washer is about 2mm thick copper. Here's a listing of all the models of Honda that use that particular washer if needed.
https://www.partzilla.com/product/honda/90544-283-000?ref=ab385962bba540622005b2f0c7211128bd215
I'd check Napa and the like before paying $10 + for a pair of two of them. I use a copper washer for oil drain plug in place of the stock aluminium crush washer.
luftkoph
E U.P. Mich
January 09, 2021, 08:16:52 AM »
I Anneal mine, heat it with a propane torch till red, then dunk it in a bit of oil, good as new, use it even on brake crush washers, never had problem with it, yes I have a KLR and I’m a frugal SOB
Some day never comes
WintrSol
Florissant, MO
Reply #6 on:
January 09, 2021, 09:11:00 AM »
Quote from: luftkoph on January 09, 2021, 08:16:52 AM
+1
Annealing copper washers is easy and effective.
turtle254
Livingston,Texas
Reply #7 on:
January 09, 2021, 09:15:52 AM »
Quote from: FLAVALK on January 08, 2021, 04:58:54 PM
I though the left leg was the damper rod ... right was cartridge type?
=> InZane XXV
