August 01, 2025, 12:44:50 AM
Needle from the diaphragm?
Topic: Needle from the diaphragm? (Read 1485 times)
GL15Brewer
Wherever I may roam
January 18, 2021, 02:24:41 PM »
So I finally got my carb rebuild kit. Working on getting it all back together. Wondering how to get the needle off the diaphragm to replace it. Also do I have to separate all the carbs to replace the fuel rail o rings? Thanks for the help. Getting excited to hear her run again.
WintrSol
Florissant, MO
Re: Needle from the diaphragm?
January 18, 2021, 02:28:51 PM »
Do you mean #3 on this diagram:
https://www.partzilla.com/catalog/honda/motorcycle/1998/gl1500ct-a-valkyrie-tourer/carburetor-components
GL15Brewer
Wherever I may roam
January 18, 2021, 02:31:40 PM »
Yes. I have a all balls kit and it comes with a new needle? I am really good a breaking things and didn't want to chance ripping the diaphragm.
Mooskee
Southport NC
January 18, 2021, 02:54:44 PM »
Take a cover screw and thread it into the top of the square needle holder. It is threaded. Pull on the screw and the needle holder assembly will come out. The holder has an O-ring on it. The needle has a washer at the top. After you replace the O-ring and the needle and washer, drop the needle into the diaphragm holder. the holder with the O-ring will slide in and then snap into the diaphragm piece. If your new needles have clips, you will need to put them on prior to snapping the holder back in. Stock needles do not have clips.
Valkyrie Carbs and Custom
www.valkyriecarbsandcustom.com
GL15Brewer
Wherever I may roam
January 18, 2021, 04:56:34 PM »
Mooskee thanks much. Made that easy. Hoping to get the carbs finished and reinstalled tomorrow.
Mooskee
Southport NC
January 18, 2021, 06:08:14 PM »
You're welcome. Take your time and pay attention to detail. You will get er done just fine.
=> InZane XXV
