December 30, 2025, 01:15:56 AM *
Author Topic: Broke starter Bolt question  (Read 1244 times)
Stick
Sherbrooke Nova Scotia
« on: February 12, 2021, 09:19:41 AM »
I just purchased another interstate upon doing my big detail and check over noticed the one bolt on the starter is broke ( I though was just missing but bolt is in there) going by the cleanliness and shape of bolts on the Kuryakyn transmission covers, it’s been this way for a long time???
Should I worry about it or is it going to cause issues?
It is the one directly above fluid reservoir
2001 Valkyrie Interstate Burgundy/Black*Sold*
2000 Valkyrie Interstate-Black*Sold*
2000 Valkyrie Supervalk-Blue/Silver*Sold*
« Reply #1 on: February 12, 2021, 01:30:10 PM »
If you think there would be enough sticking out of the block once the starter is removed so you can either grab it with vise grips or lock a couple nuts onto it, I’d give a college try at a removal
Stick
« Reply #2 on: February 12, 2021, 05:57:32 PM »
Took your advise loosened  starter enough to slid back and I have like 1/4  to grab not long enough to fit two nuts so tried the Bose grips can seem to get a grip just rounding off bolt
I soaked it in on blaster and Will attempt again in morning
« Reply #3 on: February 12, 2021, 06:44:05 PM »
+1 good suggestion.
I didn't look, is there 2 or 3 mounting points? 3, like the alternator, and it's been that way for a whole, I wouldn't worry, but try to fix like you're doing.
Good luck.
ridingron
Orlando
« Reply #4 on: February 12, 2021, 08:16:41 PM »
Maybe some heat? Heat gun or hair dryer?
« Reply #5 on: February 13, 2021, 05:28:23 AM »
+1 on heat
idaida98
« Reply #6 on: February 13, 2021, 06:21:27 AM »
Center punch,left handed drill.It may back out while drilling.Works for me at times.
Avanti
Stoughton, Wisconsin
« Reply #7 on: February 13, 2021, 06:37:01 AM »
Lots of good suggestions here.
I take a nut, set it over the stud that’s left and weld the nut to the stud. Now you have a hex head bolt again that has been heated.
h13man
Indiana NW Central Flatlands
« Reply #8 on: February 14, 2021, 10:09:29 AM »
I think you're on right track with PB & heat. Be patient and wiggle it back and forth with each application. It should eventually break loose as there seems to be little room to approach otherwise with any power assisted tools other than a right angle air grinder at best. Patience.
