December 30, 2025, 01:14:06 AM *
Author Topic: Rotors  (Read 1322 times)
muscrat
My Shrink
Tilbury On, Southern most area of Canada
« on: February 22, 2021, 09:57:08 AM »
Hey all: I have 97 Standard and am in the market for front and rear rotors and calipers. Interested in very good used or where anyone suggests the best priced new ones. Not chines knock-offs, thank you. I know there are some differences on the 97's in bearings, etc, so want to be sure on fit if someone has used.
Thanks for all responses
muscrat, Ontario, Canada
So Many Roads, So Little Time !
« Reply #1 on: February 22, 2021, 02:30:59 PM »
All Valkyrie front rotors fit every Valkyrie. You need to buy the older style rear disk if you have the original 97 wheel. The new thicker in the center disk will not work in the rear
« Reply #2 on: February 22, 2021, 03:31:01 PM »
go lighter and reduce some un-sprung weight. sometimes searching for one of the other bikes will bring a lower price. a lot of listings, they like to attach a premium $$ because of the word "Valkyrie".
I'm running a lighter GL1500 rear rotor.
HONDA ST 1100 Pan European L-Y,1 SC26  F440  Rear 1990-1992
HONDA ST 1100 Pan Europaen ABS-TCS AN,AP,AR,AS SC26 F440 1992 - 1995
HONDA VTX1800/VTX 1800C C1-CA8  SC46 e4*0113 Rear 02-09
HONDA VTX 1800F  F SC46 e4*0113 Rear 2005-2011
HONDA VTX 1800N N SC46 e4*0113 Rear 2004-2011
HONDA VTX 1800R R1-R7 SC46 e4*0113 Rear 2002-2007
HONDA VTX 1800 S  S1 SC46 e4*0113 Rear 2002-2007
HONDA VTX 1800T T SC46 e4*0113 Rear 2007-2011
HONDA GL 1500 Goldwing L- SC22 E931 1990-2000
HONDA GL 1500 Goldwing A SC22 E931 1990-2000
HONDA GL 1500 Goldwing Interstate I 1990-2000
HONDA GL 1500 Goldwing SE SC22 E931 1990-2000
HONDA GL F6C VALKYRIE /GL 1500 Valkyrie C (SC34/H582) 1500CC 1997-2003
HONDA GL 1500 Valkyrie C /CD /CF  (SC34/H582) 2000-2003
HONDA  GL 1500 Valkyrie Interstate CI (SC34/H582) 2000-2003
HONDA GL 1500 Valkyrie Tourer CT SC34 H582 1997 - 1999
I have set if used VFR800 rotors installed. within new specs for $80 ebay.
Front OEM rotors = 3.25 lbs ea
Both are the same and fit valkyrie.
Front VRF800 rotors = 2.75 lbs ea
Front CBR600F4 rotors = 2.75 lbs ea
Front GL1800 rotors
muscrat
My Shrink
« Reply #3 on: February 23, 2021, 04:21:13 AM »
Many thanks for the git back and the alternative parts that are interchangeable. Deeply appreciated.
« Reply #4 on: February 23, 2021, 04:44:59 AM »
There's two kinds of Valkyrie rear wheels. The kind on all the Interstates and all Valkyries
starting in 2000... and the kind on Tourers and Standards up to 1999. I don't know nothin'
about that giant rotor list, but even Valkyrie rotors don't interchange unless you bother to
match them to whatever year wheel you have...
« Reply #5 on: February 23, 2021, 05:27:07 AM »
I've read that before.
here is my experience.   I have a '98.  picked up a later yr factory polished wheel with the rotor. It installed with zero problem. the newer rotor is heavier/thicker than the '98 rotor. I replaced it with a lighter GL1500 rotor which lighter than the '98 rotor, bolted right on, zero problem with installation.
the list is all bikes that use the same rear rotor size and bolt circle as the valkyrie.
« Reply #6 on: February 23, 2021, 03:41:33 PM »
OP: don't blame me if you buy some cheap wonky rotor based on
stuff you read here and it doesn't fit your motorcycle.  cooldude
« Reply #7 on: February 24, 2021, 07:22:09 AM »
This  cooldude
dpcarson
Lillington, NC
« Reply #8 on: February 24, 2021, 05:13:59 PM »
Muscrat.  I have some Calipers I am in the middle of cleaning up now.  Have an old bike that I am parting out and those are not spoken for yet.
« Reply #9 on: February 24, 2021, 05:22:58 PM »
I like non-road-rashed used calipers... they can generally be cleaned
up and refurbished good-as-new...
Black rear calipers came off an Interstate. I can't imagine that they're
not interchangeable with a Standard/Tourer but they are different...
smaller pistons.
OP: what happened to your calipers that they can't be refurbished?
