December 30, 2025, 01:14:20 AM *
Author Topic: Solved: 2000 Standard Tourer just died will not restart  (Read 1438 times)
cogenguy
Bakersfield CA
« on: February 26, 2021, 12:04:24 AM »
Riding home this morning bike died on I-5 and had to have it towed to house.  While waiting for tow truck I tried numerous times to restart with no luck.  Bike will crank and is getting gas from the smell of it when turning on the choke.  Just went over 100k miles and getting ready to take care of some maintenance.  Just rebuilt the petcock and do believe that is not the problem.  I suspect the ignition system but will know more once I get time to look at it.  How easy is the alternator to remove and rebuild?  Thanks to all in advance
« Last Edit: March 02, 2021, 05:54:48 PM by cogenguy » Logged
Jims99
Ormond Beach Fl.
« Reply #1 on: February 26, 2021, 05:06:34 AM »
If it just died with out warning, I would say it’s electrical. If it still cranks it wouldn’t be the alternator. If that went bad the battery would be dead. Check for spark first.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
« Reply #2 on: February 26, 2021, 05:12:40 AM »
Check this simple thing: it is possible for the kill switch to be rocked to
half way on and half way off. My bike died once when I was 10 miles down
the road... turned out I had kind of bumped the switch to that half way place
doing maintenance. I never use the switch so I didn't think of it until after
some head scratching...
Steel cowboy
Spring Hill, Fl.
« Reply #3 on: February 27, 2021, 05:02:06 AM »
Check your lean (tilt) censor. It will kill the ignition if you were to fall over. Maybe went bad or fell over.
2001 black interstate
2003 Jupiter Orange wing
indybobm
Franklin, Indiana VRCC # 5258
« Reply #4 on: February 27, 2021, 05:24:34 AM »
If the engine is turning over when you press the starter button, it is not the Kill Switch or the Tilt Sensor.  Charge your battery and try again. Valks need full voltage at the battery to start.
So many roads, so little time
VRCC # 5258
Savage
United States
« Reply #5 on: February 27, 2021, 09:00:47 AM »
Check for whether or not you are getting spark, then let us know!
Columbia, South Carolina
« Reply #6 on: February 27, 2021, 04:33:15 PM »
Jump it to your car (engine of car not running). If it starts it’s probably the alternator. If it was the battery but the alternator was good it would not have died. But, the battery will need a full charge if it’s still good.
« Last Edit: February 28, 2021, 05:03:15 AM by Chrisj CMA » Logged
Warlock
Magnolia, Ms
« Reply #7 on: February 27, 2021, 06:19:59 PM »
Also check to vacuum operated fuel valve. Pinched vent tube could be pinched. Could be so many different things with seeing the bike. Lot of good advice to get him started trouble shooting problem.
David
cogenguy
Bakersfield CA
« Reply #8 on: March 01, 2021, 05:04:34 PM »
Problem solved.  Found the vacuum line to the fuel petcock had come off.  Should have checked this when I was broke down.  12 hour night shift and tired just wanted to get home so did not check anything my bad.  Should of, could of, would of.  Life is good.  Thanks for all the good info and advice.
Steel cowboy
Spring Hill, Fl.
« Reply #9 on: March 02, 2021, 04:54:25 AM »
Glad you got it !!! You can add to your title “solved”, so we can all learn of your find.
