December 30, 2025, 01:15:38 AM *
Author Topic: Molybdenum Disulfide Paste - Just Because  (Read 2297 times)
RustyValkry
New Jersey
« on: March 25, 2021, 08:50:27 AM »
As I was smearing moly paste all over my . . . gears and splines (because I want my gears and splines to be REAL SLIPPY), I accidentally read part of the label.  Normally I wouldn't do something as rash as reading a label of a product I'm depending upon to keep one of my motorcycles running well but it was . . . an accident.
Anyway I believe (I can't swear to it at this point because, as I said, I accidentally glanced at the label in passing) that I saw that it was 65% molybdenum disulfide.  It wasn't until later that I found myself questioning, "wait 65% . . . is that enough?"  At what point is it moly paste vs. moly grease".  This started me grazing on the old interweb looking for enlightenment.  So far I've not found much.
But I did find what's linked below.  I haven't read it all yet but what I have read is interesting so I thought I'd share in case there are any other nut cases here like me that find useless information useful.
BTW, if anyone can answer my question, "At what % of molybdenum disulfide does moly paste become moly grease.", I'd appreciate hearing it.
https://apps.dtic.mil/dtic/tr/fulltext/u2/716940.pdf
« Reply #1 on: March 25, 2021, 09:04:14 AM »
I'm not sure what kind of moly paste you got, but moly grease is like 2 or 3 percent...
Your paste is probably  cooldude ...
Question:
What is the percentage of molybdenum disulfide in this product?
Answer:
The Valvoline Moly-Fortified Multi-Purpose Grease - 14.1oz (VV633) is 1% molybdenum disulfide.
By Valvoline Product Support Manufacturer on March 5, 2019
Grandpot
Fort Mill, South Carolina
« Reply #2 on: March 25, 2021, 09:18:39 AM »
Question:
Answer:
You are absolutely correct.   Moly GREASE is 2% to 3%.  I've seen it as high as 6%.
Moly PASTE on the other hand is mostly Moly.  The Moly which is similar to graphite, needs to be suspended in a carrier so it will stick.  That's why you will not see 100% moly.
WintrSol
Florissant, MO
« Reply #3 on: March 25, 2021, 09:58:36 AM »
My dad once brought home a can of 100% moly - it's a powder, almost black. It was purchased in this form so the company we worked for could mix it to custom specs. Not very useful un-mixed, and was messy like printer toner.
« Reply #4 on: March 25, 2021, 03:27:09 PM »
Now that all that moly stuff was cleared up, you’ll be shocked to know that most of us don’t use moly paste. The most common product is Bel Ray waterproof grease. A member (RATDOG) use to mix paste with Bel Ray and called it a schmooie. My last valk never saw any paste and I sold it with 155K and the original splines were perfect.
« Reply #5 on: March 25, 2021, 03:32:32 PM »
most of us?
I've tried it, because of your endorsement... if we had a goo poll, I'd
guess moly paste would win... I have a whole new bottle of loctite
moly paste, enough that they'll probably be able to lubricate the
hinges of my coffin with it  Roll Eyes ...
RustyValkry
New Jersey
« Reply #6 on: March 25, 2021, 04:00:28 PM »
I have a rule, for the first service for a new (to me) bike I attempt to do it by the book.  After that I might take poetic license.  I figure every machine has its eccentricities and initially I might not know what they are so I play it safe.
BTW, I mixed some of the Bel Ray in a couple places . . . just because.
I can tell you one thing for sure, it'll be a while before I pull that damnable final drive out again.
« Reply #7 on: March 25, 2021, 04:06:20 PM »
Hopefully that'll be a few years down the road Mike.
pancho
Bonanza Arkansas
« Reply #8 on: March 25, 2021, 06:20:31 PM »
Only if you specify it your will,, and leave instructions as that stuff tends to get everywhere!
Ramie
2001 I/S St. Michael MN
« Reply #9 on: March 25, 2021, 06:57:47 PM »
Sodbuster had a good post about this.
http://www.valkyrieforum.com/bbs/index.php/topic,23305.0.html
« Reply #10 on: March 25, 2021, 07:02:33 PM »
Sodbuster's pictures are good and I think they say what the
manual says. Still... there's those people who use blue
belray everywhere and have good "splines"...
« Reply #11 on: March 25, 2021, 07:38:34 PM »
        As it Is pouring right now I will Not go into the garage and look but I bought my moly paste from a supplier in Texas. Looks silvery gray when the lids off. Had in time for my first service and now at 140 G on the clock Still plenty left as long as I'm alive. And B T W splines still show mill marks. Yup-you'd be Hard pressed fer me to use Anything else on Phatt Ghurls splines. Seemed to me-memory  2funny-it was good in excess of 200000 P S I pressure as it was used on drill rigs.  RIDE SAFE.
« Reply #12 on: March 25, 2021, 07:59:00 PM »
It is pouring here now too, and the time between the lighting and
the thunder is almost nothing...  Tongue ...
« Reply #13 on: March 26, 2021, 05:38:48 AM »
My feeling on the grease for the final drive is it HAS to be water resistant. If moly was used the splines have moly embedded in the metal. I never clean the splines with any solvent. Just a clean rag. Any heavy duty grease that’s stays put and stays greasy is going to protect the splines especially if they have been treated with a moly product. I use a tiny bit of moly paste and mostly heavy duty waterproof grease. See my slide show
« Last Edit: March 26, 2021, 06:15:45 AM by Chrisj CMA » Logged
rug_burn
Brea, CA
« Reply #14 on: March 26, 2021, 04:37:31 PM »
I don't think you want too high a concentration of moly, in any case-   years ago i read an article which said it was actually an abrasive in very high concentrations.    It needs to be used sparingly with lots of grease.
FWIW.
...insert hip saying here..
pancho
Bonanza Arkansas
« Reply #15 on: March 26, 2021, 06:51:38 PM »
might want to recheck that article rug_burn ,,  something is wrong there.
 https://www.sciencedirect.com/topics/engineering/molybdenum-disulfide
« Reply #16 on: March 27, 2021, 08:15:53 PM »
I use this moly paste.   Paste is more solids and less suspended oil.  Grease is more suspended oil and less solids.
https://www.tsmoly.com/anti-seize-lubricants-compounds-moly-paste-with-mossub2sub-p-93.html
this was the guard dog product which came out after I acquired the 70% moly paste.  no longer called guard dog.
https://www.tsmoly.com/grease-spline-grease-p-367.html
« Reply #17 on: March 28, 2021, 03:40:45 AM »
They're looking at stuff to replace or augment silicone
in computer chips... they've made stuff about as small
as is possible with silicone. There a class of "2D"
materials like graphene that can be used and made
as thin as just a couple of atoms.
  One such 2-D material that has shown promise because,
  unlike graphene, it is a good semiconductor, is
  molybdenum disulfide, he adds. It has already
  been used to create flexible electronics and a simple
  microprocessor.
