August 19, 2025, 03:28:23 AM *
Author Topic: Signal Boss Issue on 99 Interstate  (Read 996 times)
moreira72
VRCC# 33494
Clark, NJ. 07066
« on: March 26, 2021, 05:16:57 AM »
I recently installed the Jersey Signal Boss on my 99 I/S. Everything works as it should, Auto-cancel, Hazards, and Parade mode work fine.
My issue is when I release the brakes (front or back) in any gear the hazards flash twice. And if I have the turn signals on when I apply the brakes, they cancel and hazards flash twice when I release the brakes. only does it in gear. in neutral the hazards don't flash when brakes are applied and release.
Let's say I'm approaching on a turn, turn on my right or left turn signal, and brake to slow down, the turn signal gets canceled and when I release the brake the hazards flash twice.
I don't have any brake modulators or LED bulbs that might be causing this.
Just wondering if anybody else has this issue?
I have the auto-cancel set to about 10 seconds
« Last Edit: March 26, 2021, 05:19:30 AM by moreira72 » Logged
« Reply #1 on: March 26, 2021, 05:33:19 AM »
If Jersey doesn’t respond here I would send him a pm. He’s great at diagnosing his stuff
Jersey
VRCC #37540
Southern Maryland
« Reply #2 on: March 26, 2021, 05:36:46 AM »
Moreira72,
I sent you an email.  Rather not do troubleshooting on the forum.
Steve
Jersey
moreira72
VRCC# 33494
Clark, NJ. 07066
« Reply #3 on: April 02, 2021, 12:48:26 PM »
Moreira72,
Steve
The Question was not addressed directly to you Steve. I was trying to get feedback from possible users of the signal boss that may be having or had the same issue as I'm having. There may be a member that had the issue and corrected on their own. After all, this is a tech board.
moreira72
