October 08, 2025, 07:17:32 PM *
Author Topic: Tpms and balance beads  (Read 1310 times)
« on: May 31, 2021, 06:28:56 PM »
Has anyone tried this and is so any problems?  I know our valks dont have TPMS but there are several here thAt have wings also. Inquiring minds and the like.
Mooskee
Southport NC
« Reply #1 on: May 31, 2021, 09:11:49 PM »
Yes. I run a TPMS with Dynabeads. No problems.
« Reply #2 on: June 01, 2021, 05:06:12 AM »
Thanks Moo cooldude
Grandpot
Fort Mill, South Carolina
« Reply #3 on: June 01, 2021, 07:25:37 AM »
The pressure sensor is located on the inside of the rim at the Schrader valve.  When the tire spins, the bead are slung out against the inside of the tire.  The beads will not interfere with the pressure unit.
« Reply #4 on: June 02, 2021, 05:07:29 PM »
I've the aftermarket screw on TPMS on the valve stem, and the bulk beads in my tires. I've not had any problem, but realistically only 5K miles on them.
SunshineNomad
Ft. Lauderdale
« Reply #5 on: June 02, 2021, 05:36:51 PM »
FOBO Bike TPMS and beads in 5 bikes. Never an issue
"Keep thy eye on the tach, thine ears on the engine.
Lest thy whirlybits seek communion with the sun"
F6Dave
« Reply #6 on: June 03, 2021, 07:36:32 AM »
I switched from beads to BBs. They cost much less, work just as well, and don't clog up the valve core.
For TPMS I use the Show Chrome TireGard system with the sensor in the valve cap. It shows pressure as well as temperature. Yesterday I was riding the F6B in Wyoming, where interstate speed limits are posted at 80 MPH. Ambient temperature was 72 degrees. My front tire read 73, but the rear tire was 106! No wonder the rear tires don't last on these bikes. BTW the pressure on the rear increased by nearly 10 PSI.
Gondul
VRCC #408
Central Florida
« Reply #7 on: June 04, 2021, 06:37:15 AM »
Many also use airsoft beads...
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
F6Dave
« Reply #8 on: June 05, 2021, 05:27:48 AM »
Used those too. They're easy to retrieve if a few spill on the floor. They make a distinctive sound when rolling the bike around.
