August 21, 2025, 10:36:46 AM *
Author Topic: Idling issues  (Read 638 times)
fullray
« on: June 07, 2021, 08:19:35 AM »
Hey can anyone out there help me out? I have a 1998 Valkyrie GL 1500C had the carbs rebuilt and cranks and runs great for about 3 miles then idle goes up to about 12-1400 RPM any ideas what is causing this issue?
Ramie
2001 I/S St. Michael MN
« Reply #1 on: June 07, 2021, 09:13:01 AM »
Any chance your choke is stuck on?
Bret SD
San Diego, Ca.
« Reply #2 on: June 07, 2021, 09:40:00 AM »
I had the same issue after rebuilding my carbs, the idle screw turns itself while riding due to vibration sometimes up to 2000 idle rpm. I got a cheap mini long nose vice-grip at HF and clamped it on the screw head, no more wandering idle..
To date I've been too lazy to tear it apart and figure out what went wrong. I suspect the holding spring under the screw is missing or bad? I don't remember removing the idle screw when rebuilding the carbs.
Bret
02 Standard -- Blue & White
82 Aspencade -- Red
fullray
« Reply #3 on: June 07, 2021, 10:04:18 AM »
No choke is good I have checked that and every time I crank it the idle is fine just when i ride about 3-5 miles. If it has a vacuum leak would that cause it after the engine gets hot?
« Reply #4 on: June 07, 2021, 10:55:18 AM »
The idle speed does rise as these monsters warm up. Have you adjusted the idle speed once the engine has warmed up ?  It might then seem a bit low when cold, but, it should still stay running fine. They warm up quick.
fullray
« Reply #5 on: June 07, 2021, 11:00:13 AM »
I have tried it all. some reason when it does this it seems to be running lean on 5 and 6 pipes they are brand new and starting to blue already.
Avanti
Stoughton, Wisconsin
« Reply #6 on: June 07, 2021, 11:04:27 AM »
Are all your intake runners sealed at both ends properly.
fullray
« Reply #7 on: June 07, 2021, 11:12:45 AM »
I'm sure they are simply because the first guy that tried to rebuild my carbs had them all bent up going in had to buy new seals for the next mechanic.
« Reply #8 on: June 07, 2021, 01:12:23 PM »
Has the bike been desmogged ? Are the intake taps properly capped ?
fullray
« Reply #9 on: June 08, 2021, 08:38:58 AM »
Patrick it has not been desmogged but I am going to check the caps this weekend. Thanks
