January 30, 2026, 06:32:14 AM *
Author Topic: Loose hoses from air rails  (Read 2418 times)
almaoliphant
« on: January 06, 2010, 06:37:29 PM »
On the standard Valkyrie carb, does anyone know what the air rail hoses are supposed to be connected to?  I have two 6" long hoses, each connected to a "T" junction on the air rail of the carbs, but both are hanging free on the other end.
The fuel rail makes sense... fuel from the tank feeds into the carb fuel rails.  But the air rail hoses seem to be unnecessary.  I've looked around the general area, and can't find anything for these hoses to hook to.  The Clymer manual doesn't seem to shed light on the subject.
Any help is appreciated.
Thanks all.
Alma
Slammer
Lafayette,La.
« Reply #1 on: January 06, 2010, 06:58:06 PM »
put them thru the 2 holes in the cross brace and forget.....
sugerbear
wentzville mo
« Reply #2 on: January 06, 2010, 07:47:47 PM »
they connect to nothing
almaoliphant
« Reply #3 on: January 07, 2010, 06:55:03 AM »
Thanks for the comments.  Huh!  I hope air doesn't get sucked back into the engine through the air rails.  What would be the point of that big air cleaner if air entered the engine through the air rails?
Are these "vents" necessary, or can they be plugged?  Perhaps they're an artifact of some previous smog control system?
Warlock
Magnolia, Ms
« Reply #4 on: January 07, 2010, 07:05:51 AM »
One is the vent from the top of the carbs and the other should be a drain line from the bowls.
David
Pete
« Reply #5 on: January 07, 2010, 10:36:09 AM »
If you are referring to the 2 carb vent hoses(one for each side, on top of the Carbs). NO you cannot stop them up. They are there as a vent to the carb. If they become stopped or clogged the bike will run very lean or not at all, usually not at all, since gas will not flow thru the carbs.
They function as a vent to the bowl and carb and are not used to supply air to the intake track. Route them so water cannot enter them, ever, and leave them open.
Pete.
« Last Edit: January 07, 2010, 01:30:39 PM by Pete » Logged
almaoliphant
« Reply #6 on: January 07, 2010, 11:23:37 AM »
Pete:  Yes, those are the hoses to which I'm referring.  Thanks for you comments.  That was exactly what I needed to hear.
