August 16, 2025, 10:48:42 PM
idler bearings and timing belts.
Topic: idler bearings and timing belts. (Read 1728 times)
baird4444
June 13, 2021, 09:55:13 AM »
my idler wheels have been whining a bit in cold weather and it seems as though the timing belts are singing a little more... going to do the generic idler mod #1 and belts, 97K so might as well. can anyone SHARE a link to the timing belt process? I used to have one saved where someone did an awesome write up and diagrams but I can't find it.
Thanks in advance- Mike
- ya gotta be SOBER!
-Cody Baird
SunshineNomad
Ft. Lauderdale
Re: idler bearings and timing belts.
June 13, 2021, 10:51:42 AM »
At 97k, there’re due. They might look ok, but inside they might be deteriorating. A change of tensioner is recommended since it’s apart
Here’s a link:
http://www.valkyrieforum.com/bbs/index.php/topic,56195.0.html
Also YouTube has quite a few videos for reviews. Gl 1500 and Valk are identical.
Gates T275 belts are cheaper than OEM.
"Keep thy eye on the tach, thine ears on the engine.
Lest thy whirlybits seek communion with the sun"
baird4444
June 13, 2021, 10:08:57 PM »
Thanks Seth, I've got the tensioner plans, it's the BASIC timing belt documentation
I'm looking for.
- Moike
-Cody Baird
Bone
June 14, 2021, 02:44:44 AM »
Here's a couple of links I've saved. Have not tried either one.
http://www.sdb-e.com/TENSIONER/TENSIONER-REBUILD-JCS.pdf
http://www.valkyrieforum.com/bbs/index.php/topic,54029.0.html
-mike-
Germany
June 14, 2021, 03:15:19 AM »
Quote from: baird4444 on June 13, 2021, 10:08:57 PM
I'm looking for.
- Moike
This is the document I have found some time ago and saved. Maybe it does help.
https://drive.google.com/file/d/1UZqbQu-7esxaVJi0Hx05VTvbB_4mJqMZ/view?usp=sharing
-mike-
baird4444
June 14, 2021, 05:24:48 AM »
AWESOME!!
this is better than the one I remembered....
Thank you very Much - another Mike
-Cody Baird
jnicks01
Clinton, IN
Reply #6 on:
June 14, 2021, 05:37:32 AM »
This is my go to site for almost everything.
https://www.valkyrieworld.com/test-docs
I want to scoop out your brains and eat your knowledge.
Reply #7 on:
June 15, 2021, 06:45:05 PM »
there are holes on the back of the pulley support plates which allow adding grease to them under the seal with a needle fitting. try 1/4 pump of grease gun, then spin them and listen to them.
baird4444
Reply #8 on:
June 16, 2021, 07:16:05 PM »
Quote from: jnicks01 on June 14, 2021, 05:37:32 AM
AWESOME page, thanx for sharing!!
-Cody Baird
=> InZane XXV
