November 12, 2025, 11:39:32 AM *
Author Topic: Electrical question(s)  (Read 1077 times)
TrapperAH1G
Toledo, WA
« on: June 18, 2021, 12:25:58 PM »
Where is the fuse box?  Looking in the manaul and can't find it.
Playing around with wiring passing lights, hooked them up, didn't work like I thought so unhooked.  Now.....no neutral light, no running lights, no tach.  That's all I've found so far, haven't ridden.  Brakes, turn signals, headlight, etc. all operate.  Hoping I popped a fuse.
Help?
« Reply #1 on: June 18, 2021, 01:09:13 PM »
Fuses are behind the right side side cover. Don’t break the tabs On the side cover
Bagger John - #3785
« Reply #2 on: June 18, 2021, 01:22:01 PM »
Passing lights are best run through a switch-activated relay controlled by the bike's high/low beam wires. The relay supplies power to them directly from the battery - never via the bike's wiring harness.
Search the Tech Forum for "driving light relay". Should come back with threads and schematics on how to do it right.
TrapperAH1G
Toledo, WA
« Reply #3 on: June 18, 2021, 05:35:43 PM »
thanks to both of you.  Got all working again and took a 12 mile check ride.  I have a Shadow Tourer 1100 and the driving lights on it work fine.  I copied how it was done, didn't work quite the same on the Valk.  I did confirm on the wiring diagram that both bikes use the brown/white wire for the turns.
Lots of good info on the search for driving lights.  Gonna start from scratch next week.  Have a bike show and poker run tomorrow.....no work on Sunday.  Thankfully, the weather's gonna be nice for the next few days.
Take care, be safe.
