November 12, 2025, 08:29:10 AM *
Author Topic: Carb Rebuild  (Read 1420 times)
clar1jam
« on: June 21, 2021, 10:05:48 AM »
When rebuilding carburetors do you use adhesive on the bowl gaskets or what would you use.
itsblue
Blairsville GA
« Reply #1 on: June 21, 2021, 12:12:34 PM »
I used a little red and tacky grease to hold them in place. Don't know if it matters but also kept each carbs parts separated for reassembly.
yrunvs
Prior Lake, Minnesota
« Reply #2 on: June 21, 2021, 04:08:31 PM »
like itsblue said a very very thin layer of red rubber grease. You dont want to introduce anything that could break free and clog a jet or passage way.
I'm no gynecologist but hey I'll take a look!
Mooskee
Southport NC
« Reply #3 on: June 22, 2021, 08:44:36 AM »
I used the recommended 3M 847 on the first carb set I rebuilt. It cost $16 for 5 oz. It is very difficult to apply without overrun. Then I had to clean up the gasket and surface before installing.
I have since rebuilt 6 more sets of carbs. I have not used the adhesive. I use Redeye's kits and clean the bowl groove with the plastic pic. I then use the test tools he sends to test the seal. The only thing I have done during assembly is dip the gaskets in Seafoam. I haven't had any reports of leaks on any of the carb sets.
My logic:
1. The surface on the carb body does not have adhesive from the factory.
2. The glue is messy, and if one were to leave any residue in the bowl area, it could introduce foreign material into the carb and plug a jet or a passage.
3. it works without it.
4. I test the seal to verify it will hold a vacuum.
DeathWishBikerDude
« Reply #4 on: June 23, 2021, 04:29:03 AM »
YouTube has a couple good videos on call carb rebuilding and jet replacement.
Ron in Buffalo
Buffalo, NY
« Reply #5 on: June 24, 2021, 05:49:17 AM »
This guy has the most complete guide to rebuild Valkyrie carbs.
 https://youtube.com/channel/UCgIuEAkXryNo8aLGsozDTvQ
1997 Valkyrie & 2002 BMW F650GS
