January 30, 2026, 06:32:21 AM
Any suggestions?
Topic: Any suggestions? (Read 2284 times)
rikb
Mesa, AZ
Any suggestions?
January 07, 2010, 02:45:38 PM »
Hey Guys:
I am installing a new driveshaft and having trouble seating it into the u-joint. It goes in far enough to just barely engage the 4 mounting bolts in the flange, but stops about 3/4" shy of flush.
Any secrets or techniques I can try?
Black Dog
VRCC # 7111
Merton Wisconsin 53029
Re: Any suggestions?
January 07, 2010, 03:13:20 PM »
Try to hold the swing arm as close to 'normal position' as possible (don't let it hang down)... They can be a dog, but all of a sudden, they pop right in...
Black Dog
Don't you know...
January 07, 2010, 03:14:19 PM »
Sit directly behind the bike. With the drive shaft secure in the pumkin look down the tube and move the swing arm until you see the ujoint lined up...(a flashlight might be required at first) this is just to know at which angle the swing arm needs to be at. Now slide her in and move the swing arm up and down a tad if need be.....if still stubborn, you can try putting the driven flange piece in the hub so you can spin the thing as it tries to go in
rikb
Mesa, AZ
January 07, 2010, 03:21:20 PM »
Eureka! Thanks guys, that was the magic. I lifted the swingarm up and down several times and it slid home like it should. Appreciate the help!
January 08, 2010, 08:39:18 AM »
If you have the swingarm unsupported it will cause damage to the universal joint if the universal is allowed to become the support for the swingarm.
It damages the bearing cups ends and seals.
Always support the swing arm when the shocks are unattached.
