February 12, 2026, 07:32:18 PM *
Author Topic: Intermittent cooling light  (Read 1599 times)
Rosie
Clintonville WI 54929
« on: July 12, 2021, 07:51:22 PM »
My Temp. light comes on then goes off. Sometimes it just flickers ,sometimes stays on for 30 seconds. Radiator and overflow properly filled, fan works and not overheating. I read that a bad coolant indicator #38710-MZO-003 could cause this. Part is N/A. Any suggestions or alternative part that will work. Thanks.
1999 Valkyrie tourer
2003 Valkyrie standard
« Reply #1 on: July 12, 2021, 10:21:04 PM »
Ignored mine for years till I sold the bike. As long as the fan operates correctly, don’t worry about it.
Fazer
« Reply #2 on: July 13, 2021, 06:53:17 AM »
Rosie--I am going thru the same issue.  The indicator unit is no longer available, but there is an easy work around.  I found it here on the tech board.  Buy the temperature sensor that goes at the bottom of the radiator for the later model Valk.  It has a blade push-on terminal rather than the screw type for the 97-99 bikes so that will have to be changed.  You also need to jumper a couple of wires on the connectors.  It says which ones on the instructions.  Rather than buy a new one for $45, I bought a used sensor from Pinwall (on Ebay) for about $4.  If you can't find the page I am referring to, I will bring in the directions I printed and post them for you.  Here is a link to the Ebay page.
https://www.ebay.com/itm/133655365539
Nothing in moderation...
hueco
WACO,TEXAS
« Reply #3 on: July 13, 2021, 08:19:33 PM »
#1. But. I still have my bike.
Jims99
Ormond Beach Fl.
« Reply #4 on: July 14, 2021, 04:49:10 AM »
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
indybobm
Franklin, Indiana VRCC # 5258
« Reply #5 on: July 14, 2021, 05:14:32 AM »
I believe that I am the one who wrote that article. It is not the thermostatic switch that is on the bottom of the radiator, that just turns the fan on and off. The sensor that needs to be changed to the later model is located on the thermostat housing.
So many roads, so little time
VRCC # 5258
klb
Hickory nc
« Reply #6 on: July 14, 2021, 06:02:53 PM »
My 99 has done it since I bought it in 2010. It only does it a few times
a year mostly while I am running 55 or so. When it does I pull in the
clutch at speed and cut it off then turn the key back on and let the
clutch out and 99 percent of the time it never comes back on.
A few months later it will flicker or come on so I do the same thing.
Ain't worth the trouble of fixing it.
If it ever gets the best of me I bookmarked indybobm's post
about 5 years ago so I will know how to fix it.
indybobm
« Reply #7 on: July 15, 2021, 04:52:21 AM »
Let me give credit where credit is due. My article expanded upon a post from F6Dave many years ago. Thanks F6Dave.
http://www.valkyrieforum.com/bbs/index.php/topic,19430.0.html
« Last Edit: July 15, 2021, 04:59:19 AM by indybobm » Logged
VRCC # 5258
Speedy Coop
South Wales, New York
« Reply #8 on: July 15, 2021, 06:37:53 AM »
I bought a cheap wiring harness from ebay that had the module attached, so far it is working properly.
Rosie
« Reply #9 on: July 15, 2021, 08:54:01 AM »
Looking at Honda directline parts and cant find thermostat and thermostat housing. Also do you need to remove radiator to replace thermo switch by thermostat housing?
« Last Edit: July 15, 2021, 09:13:25 AM by Rosie » Logged
indybobm
« Reply #10 on: July 15, 2021, 11:32:22 AM »
Listed under 'Water Pipe/Thermostat'
https://www.servicehonda.com/oemparts/a/hon/506cb6b3f870023420a41938/water-pipe-thermostat
« Last Edit: July 15, 2021, 11:35:57 AM by indybobm » Logged
VRCC # 5258
Rosie
« Reply #11 on: July 21, 2021, 04:10:00 PM »
Thank You to all who replied.
F6Dave
« Reply #12 on: July 21, 2021, 06:01:20 PM »
Wow, that was a long time ago! It was a frustrating problem. I thought I might have a bad thermostat at first, and removed it and placed it in a pot of boiling water on the stove to check the opening temperature, using a thermometer. I finally figured out that it was that stupid 'indicator unit' under the side cover and decided to get rid of it. Now you have no choice since the indicator unit is no longer made.
