February 12, 2026, 07:33:14 PM
Desmog question.... I think
Topic: Desmog question.... I think (Read 1220 times)
Maryland Valk
August 09, 2021, 02:25:42 AM »
I am doing a Desmog on my 99 interstate with the Shiny kit. I think I have it figured out EXCEPT for a couple of vacuum lines??? coming off the top "rail" of both carb sets. The Fuel from the Petcock goes to a Lower Rail (Large) nipple and the one I am confused about goes to an upper nipple with a smaller (air hose sized) nipple. (See attached O-Ring Kit pic from REDEYE - Which is the only decent pic I could find to describe this connector) The nipples seem to rotate on their axis and I am not sure if they get eliminated or if they connect to something. I'll try to upload a pic of the actual situation tomorrow.... but the Shop Manual seems to call them "Air Vent Tubes" (AirVentTubes Pic attached) but I can't figure what they go to.
Anyway I am afraid to move on with the project until I get this piece figured out. Any assist would be GREATLY appreciated. I should have documented my steps but instead I dove head long in and now I can't remember how these lines hooked up.
Thanks so much for any advice or assistance you can give.
DOUG
yrunvs
Prior Lake, Minnesota
Re: Desmog question.... I think
August 09, 2021, 04:39:59 AM »
Those indeed are air vent tubes and go nowhere ultimately the loose ends attach to nothing. On the rear carb metal brace you should find 2 holes just poke them through and that's that.
Last Edit: August 09, 2021, 04:41:58 AM by yrunvs
I'm no gynecologist but hey I'll take a look!
Maryland Valk
August 09, 2021, 09:26:27 AM »
Thani you so much, yrunvs. I appreciate your quick, thoughtful and simple response. The of this project shoud be CAKE!!!
DOUG
mello dude
Dayton Ohio
August 09, 2021, 07:42:02 PM »
This should help too...
http://www.valkyrieforum.com/bbs/index.php/topic,108136.0.html
