July 13, 2025, 05:47:49 AM *
Author Topic: GPS mount  (Read 3565 times)
Kelm1
Beaver Dam, WI
« on: January 10, 2010, 10:58:36 AM »
I'll be mounting my Garmin 205W to the I/S before spring and found this mount.... http://www.ram-mount.com/NewProducts/MotorcycleClampMount/tabid/2038/Default.aspx. It say it will work as long as the Valk uses M8 bar clamp bolts. Can anyone verify this for me? This mount looks solid and simple and should put the GPS right where I want it.
ptgb
Youngstown, OH
« Reply #1 on: January 10, 2010, 11:45:57 AM »
Yep... according to http://www.hdlparts.com/fiche_section_detail.asp?section=148156&category=MOTORCYCLES&make=HONDA&year=1999&fveh=3467
The bolts are 8x32 (they are #14 on the fiche).
Kelm1
Beaver Dam, WI
« Reply #2 on: January 14, 2010, 02:25:48 PM »
Thanks ptgb! I'm going to give it a try.  cooldude
RALANDRY51
COLORADO SPRINGS, CO
« Reply #3 on: February 15, 2010, 08:42:33 PM »
cAN YOU TELL ME IF THAT WORKED AND IF SO WHAT RAM MOUT ITEMS YOU PURCHASED? WHAT DID YOU PLUG INTO? DO YOU HAVE IT CONNECTED TO YOUR INTERCOMM SYS IN SOME WAY?
PAVALKER
Pittsburgh, Pa
« Reply #4 on: February 15, 2010, 09:46:08 PM »
I mounted my RAM Ball on to my Top Clamp dead center, and I use a 3inch Ram Post and the GPS specific cradle.  I have a Power Port zip tied to the underside of the clamp on the handlebar actually.  I put it on plug it in and have an audio plug that extends from under the side cover up under the tank to the handlebars.... it plug in to my GPS for MP3 and GPS Audio in the AUX position.  When I remove it all you see is the ball on the top clamp and of course the power port under the top clamp.  The audio plug I slid into the zip tie to hold it in place.   I use a Garmin Nuvi 660......
John
BigM
« Reply #5 on: February 16, 2010, 10:06:17 AM »
Ram mount and I got with Kennedy electronics for my audio hookup on the I/S.They carry alot of connections etc. for bikes.
thelt
RMC(SS) USN Ret. & Retired Police Capt.
Kingsland, GA
« Reply #6 on: February 19, 2010, 03:54:29 PM »
I have a Garmin 255W. The pictures on the Ram Mount web site aren't that clear. Anybody got any idea what parts/pieces  are needed for my I/S? I've got an XM mounted on the left side already. Looking for ideas and what parts are needed from Ram Mount.
When asked what I did to make life worthwhile in my lifetime....I can respond with a great deal of pride and satisfaction, "I served a career in the United States Navy."
old grouch
Colorado Springs, CO
« Reply #7 on: February 20, 2010, 05:40:45 PM »
Thelt
I bought this one http://www.ram-mount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045066045049056054085045065/Default.aspx and it works great.  Just in case the link doesn't work, the part number is RAM-B-186U.  Enter that in the search bar at the top of the page and it will take you there.
You will need to look up the cradle that fits your Nuvi on the Ram website.  I bought mine from GPS City online.  They were a bit cheaper and shipping was less than from Ram.  Stan
09/11/01 NEVER FORGET!
