February 12, 2026, 04:11:20 PM
Filling fuel tank on standard or tourer
Topic: Filling fuel tank on standard or tourer (Read 1757 times)
Rosie
Clintonville WI 54929
August 25, 2021, 09:41:32 AM »
When you fill the fuel tank it seems to allow some fuel to go thru a little hole and if you get a good nozzle and are patient you can get more fuel in. Slow process tho. has anyone tried enlarging? this hole. Maybe a punch and wiggle it around? Dont think drilling is a good idea because of chips. Has anyone done something like this? Thanks.
1999 Valkyrie tourer
2003 Valkyrie standard
Re: Filling fuel tank on standard or tourer
August 25, 2021, 09:56:06 AM »
Wrote this up back in '98:
https://horseapple.com/Valkyrie/Tech_Tips/Burping_Brunhilda/burping_brunhilda.html
I would modify this now to say you can just use a tapered punch type tool and push and wiggle it to open the hole. The metal is soft, doesn't need to be cut. A tool like this:
https://www.harborfreight.com/pry-bar-set-3-pc-68339.html
Last Edit: August 25, 2021, 09:59:33 AM by MarkT
August 25, 2021, 02:12:54 PM »
I used an awl. You’re right about chips. Just press in and wiggle around.
Jruby38
Oxford Mass.
September 09, 2021, 04:30:31 AM »
I cant see any hole in my 99 tank filler neck.
VALKMAN
ValkMan
San Jose CA
September 09, 2021, 06:59:59 AM »
I have been using this for years, just trust it when the pump stops!!!!
https://www.amazon.com/McCuff-Motorcycle-Protector-standard-Motorcycles/dp/B0882HHFRB
Valk Man
Valkyrie Rider and Buell Enthusiast
AMA #319125 -
http://www.amadirectlink.com/index.asp
The biggest problem with the world is that most people can't get out of the way of their own ASS!
0leman
Klamath Falls, Or
September 09, 2021, 07:58:45 AM »
Quote from: VALKMAN on September 09, 2021, 06:59:59 AM
I used the McCuff when I lived in CA with their anti-vapor nozzles. Still do when I slipped over the border and go far enough to need their expensive gas. In OR don't use it.
The making the hole bigger plus a slight back and forth movement of the bike helps to get more gas in the tank at a reasonable rate. I fill the tank while straddling my Valk.
1999 Valkryie I/S Green/Silver
Jruby38
Oxford Mass.
Reply #6 on:
September 09, 2021, 09:37:43 AM »
Thanks, but I still dont see any existing hole in my tank to expand.
Gondul
VRCC #408
Central Florida
Reply #7 on:
September 10, 2021, 05:41:44 PM »
There is a 'collar' that extends down from the top of the tank.
If you are sitting on the bike it is high near the 1 o'clock position...
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
Jruby38
Oxford Mass.
Reply #8 on:
September 11, 2021, 12:42:25 PM »
thanks Gondul. I will look for it.
Jruby38
Oxford Mass.
Reply #9 on:
September 12, 2021, 11:02:31 AM »
Spot on Goundul. I found it way up at 1:00 position at like you described pinched it out bigger. Fills up to the top now is easy.
Reply #10 on:
September 12, 2021, 08:47:00 PM »
I find some gas stations nozzles suck unable to feather the lever to trickle more in slowly. They are either full blast or nothing and too much pressure. When I get a gas station like that, I NEVER try filling up way to the top not worth the risk of spilling as all over for that last 1/2 gallon of gas.
