February 12, 2026, 05:58:35 PM *
Author Topic: Symptoms of loose wheel dampeners?  (Read 1687 times)
allanbegg
Marietta, PA
« on: August 26, 2021, 06:12:12 AM »
All,
My bike ('99 I/S with 172K miles) suddenly developed a strange noise.
The noise is very easy to reproduce. It happens at the no-load point between engine acceleration and deceleration. It sounds like a "chatter" in the driveline. When the engine is pulling, everything sounds fine. When there is engine braking, everything sounds fine. However, at the transition between pull and brake, there is a terrible chattering noise.
I replaced the rear wheel dampeners, along with driveshaft, pinion cup, o-rings, etc during a rear service, but they all have about 50K miles on them.
We pulled everything apart last night and the only wear (or slack) that I can find is with the wheel dampeners. They are all loose in the pockets, with a couple moving about an 1/8 inch and a couple moving about 3/16 inch. There is a fair amount of rubber dust in the pockets. I'll replace the dampeners, but am not certain that this is the cause of the chatter.
Should I keep looking for another issue, or do these dampeners cause a racket when they wear out?
Thanks, Allan
VRCC # 36795
RonW
Newport Beach
« Reply #1 on: August 26, 2021, 06:22:30 AM »
Just wedge (shim) them tight and if the sound goes away.
« Last Edit: August 26, 2021, 06:25:59 AM by RonW » Logged
2000 Valkyrie Tourer
« Reply #2 on: August 26, 2021, 06:27:25 AM »
While it’s apart pull the u-joint. The sounds you describe do not match up to worn dampeners. I agree yours most assuredly need to be replaced the fact that they are not worse means keep looking. U-joint  is likely. How did the pinion cup look?
Bagger John - #3785
« Reply #3 on: August 26, 2021, 06:38:04 AM »
+1
allanbegg
Marietta, PA
« Reply #4 on: August 26, 2021, 07:01:25 AM »
Pinion Cup only has 50k miles on it and still looks as new as the day I installed it.
All splines on the driveshaft (also 50K miles) look great, with no signs of wear.
Opened up the differential and ring/pinion gears look beautiful.
I'll pull the u-joint later today, to get a better inspection of it.
Thanks for the input, so far.
Allan
VRCC # 36795
allanbegg
Marietta, PA
« Reply #5 on: August 26, 2021, 10:05:21 AM »
Update:
U-Joint for the win (er, fail). It is completely trashed.
I'm surprised that the bike was still rolling under it's own power.
Should be a relatively easy and inexpensive fix.
Thanks for the suggestions and help.
Allan
VRCC # 36795
« Reply #6 on: August 26, 2021, 11:07:18 AM »
Update:
Allan
 Shocked
Avanti
Stoughton, Wisconsin
« Reply #7 on: August 26, 2021, 11:51:54 AM »
That might hold a record, at least in my book it does.
pancho
Bonanza Arkansas
« Reply #8 on: August 27, 2021, 12:46:39 PM »
Wow,,,   hard to believe the only noticeable symptom was the noise. You're going to think you got a new bike when it's back together.
« Reply #9 on: August 27, 2021, 07:14:21 PM »
You might need a new boot. A little more soft and pliable, for re-installation. Alcohol makes the rubber slide, and dries completely.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #10 on: August 27, 2021, 07:26:07 PM »
Those three beers I had last time I tried to get the boot on did NOT make it easier!! uglystupid2
« Reply #11 on: August 27, 2021, 07:33:45 PM »
Grin
Grandpot
Fort Mill, South Carolina
« Reply #12 on: August 30, 2021, 03:18:26 PM »
You were supposed to pour the beer on the boot for lube.
