srelegante
« on: August 29, 2021, 04:37:53 PM » |
I am a recently new Valkyrie owner, and doing some necessary changes. I had to take the radio panels off, and some of the stays (?) that hold the screws in pulled out of the plastic, after so many years without being taken apart.
I have the necessary service done, and was going to put them back in with some gorilla glue and leave them overnight, is there a better manner to handle the situation?
I’m sure this is been covered many times, feel free to point me to an existing thread.
Thanks!
SE
Bagger John - #3785
« Reply #1 on: August 29, 2021, 05:12:21 PM » |
Use JB Weld.
Put the fairing screws in the inserts with a little silicone grease on the threads then use JB Weld in the fairing pockets. Seat the inserts and leave for 24h.
The grease prevents the JB Weld from sticking to the screws. Remove them and install your fairing components.
srelegante
« Reply #2 on: August 29, 2021, 06:16:49 PM » |
Perfect.
Will do.
Thank you!
SE
Steel cowboy
Spring Hill, Fl.
« Reply #3 on: August 30, 2021, 05:39:05 AM » |
One more thing or two, the stay has a small round disc at one end, make sure it’s still on there. And more important use anti seize on the threads before you reinstall the screws.
2001 black interstate 2003 Jupiter Orange wing
« Reply #4 on: August 30, 2021, 06:48:16 AM » |
I would replace the used inserts with new. When the screws are installed they expand the inserts to aid in retention. The inserts can be bought from Honda or from McMaster-Carr (cheaper) https://www.mcmaster.com/catalog/94510A330order the m5x0.8mm size Also, if you insert the screws prior to gluing, it will expand the inserts, you could pack the inserts with cotton or paper towel and then remove it after the glue dries.
« Last Edit: August 30, 2021, 06:51:33 AM by Skinhead »
Bagger John - #3785
« Reply #5 on: August 30, 2021, 08:55:33 AM » |
I have a bunch of new inserts. If the old ones are in too bad of a shape to re-use I'll grab a new one from the stash and install it, else the original (pre-expanded) insert gets glued back in.
Also anti-seize my screws when re-installing them.
Used to have access to a source of inserts that were a bit better design than the Honda part but I left the particular company a number of years ago.
« Reply #6 on: August 30, 2021, 11:19:41 AM » |
If it doesn't pop up in the right post, it's near the end of the second page. http://www.valkyrieforum.com/bbs/index.php/topic,96578.40.htmlSearch to should find something on it. Recommend to all new owners of IS to remove those screws and apply a little anti seize on them, before you need to try to remove the cover while on the road.
srelegante
« Reply #8 on: August 30, 2021, 03:30:42 PM » |
I would replace the used inserts with new. When the screws are installed they expand the inserts to aid in retention. The inserts can be bought from Honda or from McMaster-Carr (cheaper) https://www.mcmaster.com/catalog/94510A330order the m5x0.8mm size Also, if you insert the screws prior to gluing, it will expand the inserts, you could pack the inserts with cotton or paper towel and then remove it after the glue dries. New stays on the way! Thanks! SE
« Reply #9 on: August 30, 2021, 06:44:21 PM » |
http://www.valkyrieforum.com/bbs/index.php/topic,96578.msg1143880.html#msg1143880OK, I think I got it. point to the subject of the post I wish to zoom too, and copy that link. Came up above. I couldn't figure out what you meant of # 60, since nothing mentioned # 60 in your link. Now if I'll only remember it the next time I need it.
RonW
« Reply #10 on: August 30, 2021, 08:49:21 PM » |
gordonv, somebody taught me that in another forum.
2000 Valkyrie Tourer
Jersey
VRCC #37540
Southern Maryland
« Reply #11 on: August 31, 2021, 03:10:22 AM » |
Recommend preparing the area very well for the JB Weld.
I thoroughly clean with alcohol, then I use a Q-Tip and apply some PVC Solvent to the plastic. This is the same stuff used in plumbing and PVC piping. This will open up the plastic surface and will hold the JB Weld better.
Hope that helps, Jersey
Jersey
da prez
« Reply #12 on: September 02, 2021, 12:36:45 PM » |
Ditch the JB weld. Short term fix. BLACK ABS glue. Not multi purpose. I clean with mek. You can close the holes and redrill. I have repaired many parts. The faring is abs plastic.
da prez
Bagger John - #3785
« Reply #13 on: September 02, 2021, 12:47:18 PM » |
If you're going to close the hole and re-drill, the best way to do this is with a plastic welder and ABS filler rod. ABS "cement" - more ofthen than not - is more "solvent" than "filler" and when patching holes will result in a softer (easier to pull out or deform) repair unless one thoroughly mixes a bunch of ground-up ABS into it, forming a very thick slurry. Have had numerous experiences with the stuff on Gold Wing bodywork before going to the mixed slurry and finally the plastic welder method. FWIW, I've repaired a number of I/S fairing inserts with JB Weld and have yet to have a pullout. Some are 14 years old (my current I/S).
