February 12, 2026, 07:33:16 PM *
Author Topic: Stock horn removal?  (Read 1700 times)
« on: October 04, 2021, 07:34:46 PM »
I know this is going to sound silly and probably kind of dumb but, I've tried every tool I have that I think might be applicable to the task to remove the stock horn bracket from the frame (right behind the radiator).  I don't have a wrench or socket that will fit into that space.
Is there a special tool required for this.   The only option I can come up with is to bend the horn bracket to get to the bolt holding it.    I don't mind bending that bracket but, when I go to re-install the new horn, I don't want to have to bend that chrome bracket knowing that will result in the chrome cracking and eventually breaking off.
What am I missing?
« Reply #1 on: October 04, 2021, 08:04:47 PM »
Ron, I removed mine when I got the Stebil Horn. I don’t remember it being hard nor did I need special tools. However I don’t remember what I did but I know I didn’t have to mutilate it in any way. I still have it.
Shoot me a picture of how it looks, maybe it will jog my memory
« Last Edit: October 04, 2021, 08:07:22 PM by Chrisj CMA » Logged
« Reply #2 on: October 04, 2021, 08:42:47 PM »
If it's a wrench clearance issue, the flat honda toolkit wrenches are skinnier than most others.
3W-lonerider
Shippensburg Pa
« Reply #3 on: October 05, 2021, 05:08:47 AM »
your making it harder than it needs to be. if i remember correctly. you can remove horn and bracket with a socket. i think it a 12 or 13 mm.
Bagger John - #3785
« Reply #4 on: October 05, 2021, 06:29:14 AM »
Correct.
I bought I/S horn brackets for every Standard or Tourer I've owned, fabricated some extension wires and relocated the horns. The whole thing can be put back to stock in 15min if desired...but on my current Tourer there's now a radiator pod blocking things.
« Reply #5 on: October 05, 2021, 03:49:39 PM »
Rick,
That's what I do.   I'll try again.   cooldude
