February 12, 2026, 07:32:11 PM *
Author Topic: Vent tube....  (Read 1694 times)
spongebob
Alabama
« on: October 06, 2021, 09:29:17 PM »
Have a 2003 STD. that I bought new in 2002. The bike has Never liked WOT. period.
Done checked all the stuff...over and over again.
But anywho....
Here is my problem..
Had the tank off... changed air filter...replace fuel petcock....vent hose... vacuum hose...
Checked the vent tube going up in the tank....dang... barely can blow up tube...
Well I be darned... here is my problem after all these years.
Got a piece of electric fence wire ( sort of stiff)... run it up the vent tube... stopped after about 2 inches in. Kept working back and forth... until I got it to go in about 10 inches worth... but that was all.
put it back together.....
Put about 1 gal. of gas in it..... dang... where is all fuel coming from....  Angry
Long story I know......
But, fuel is coming out of vent tube....thus it has a crack/ hole in vent tube near the bottom of the tank.......... tickedoff
Any ideas?
I am all ears....
Has any of you seen inside of a gas tank....
matt
Derry New Hampshire
« Reply #1 on: October 07, 2021, 03:17:41 AM »
Looked inside one with scope as I had a tank if it had more than 3/4 tank it would leak. If memory serves me right tube started on right side and went over hump to left side. No idea how but yup small hole in tube. I picked up a used tank.
Speedy Coop
South Wales, New York
« Reply #2 on: October 07, 2021, 03:40:09 AM »
Cap off the vent tube and get a vented cap. Somebody will come up with the cap assembly you need.
Foozle
Lexington, KY, USA
« Reply #3 on: October 07, 2021, 05:20:25 AM »
I think MarkT (Horseapple Ranch) used a vented OEM cap from a Honda Magna or Shadow.  Do a search of the archives - or perhaps he can chime in.
Terry
« Reply #4 on: October 07, 2021, 06:07:19 AM »
Yep.  A Magna P/N.  Has a vent with check valve.  I'm sure you can find it at Partzilla microfiche.  Same fit & look as Valk cap. If you don't rekey it you will need a separate key as the key blank stagger is opposite the Valks'.  IOW you can't have one side of the key ignition, the other gas cap.  I just attached tiny colored wire ties to my keys to signal purpose.  Before I bought the vented cap I had drilled a small hole in the collar of the cap fitting.  Then closed it back off with a rivet after the cap replacement.  Now no rivet with the new I/S tank.  Temp workaround; you can put a coin under the cap seal to vent it.
turtle254
Livingston,Texas
« Reply #5 on: October 07, 2021, 06:41:02 AM »
Yep.  A Magna P/N.
What year Magna for part number? Meaning are they all vented, doesn't say any where on site?
« Last Edit: October 07, 2021, 08:34:08 AM by turtle254 » Logged
« Reply #6 on: October 07, 2021, 09:20:29 PM »
This was over 4 yrs ago & I don't recall.  I suspect they all are but you could go ask over on a Magna forum.
-mike-
Germany
« Reply #7 on: October 08, 2021, 04:19:52 AM »
Vented Honda Magna fuel cap:
Part number 17620-MB1-033
Best
-mike-
« Reply #8 on: October 08, 2021, 05:25:38 AM »
https://www.ebay.com/itm/264117316502
IDK?  This looks okay.  Sure is a lot less that Honda.
