February 12, 2026, 11:11:44 AM
Clicking noise from under engine
Topic: Clicking noise from under engine (Read 2448 times)
studlly 64
Norwood, Mass
October 18, 2021, 02:30:43 PM »
I Hear clicking noise from under the engine, I can feel it also on the footpegs, seems to happen mainly when it's cold and cruising on a slow speed.
any ideas please?
1998 ST
Re: Clicking noise from under engine
October 18, 2021, 02:42:08 PM »
Does it change with engine rpm or with speed? If it increases with speed or actually rear wheel rpm. I’d say u-joint or less likely the pinion cup splines.
studlly 64
Norwood, Mass
October 18, 2021, 02:47:40 PM »
it only happens when I'm cruising on low speed!!
1998 ST
October 18, 2021, 03:42:35 PM »
Very hard to say with the lack of info you are giving. Pull the drivetrain and check the u-joint and pinion cup splines.
Warlock
Magnolia, Ms
October 18, 2021, 09:08:12 PM »
Like Chris said check them and also check your left rear wheel bearing. They have been known to make a clicking sound also. But feeling it in your foot pegs sounds like a bad u joint.
David
ryord
November 24, 2021, 08:59:59 PM »
I recall that if the bike has not been desmoged, there was some parts in that apparatus that would make a clicking noise.
Bagger John - #3785
Reply #6 on:
November 25, 2021, 09:39:57 AM »
Quote from: ryord on November 24, 2021, 08:59:59 PM
I doubt that you could feel the PAIR Valve pulses in the footpegs.
I'm going with U-joint at this point.
cheeseman1969
Hastings NE
Reply #7 on:
November 26, 2021, 12:45:49 PM »
I would go with rear bearings as had that happen. I did not have clicking but just felt something when I was in tennis shoes only. Kinda of by accident but enough to get me to open it up. Bearings on rear was all rusted up. I changed them out and then rode to work a few days in tennis shoes and did not have it anymore. NOTE: Since doing that, I checked my final drive and everything was lubed and going smooth.
Gary "Cheeseman"
USN "weather guesser" Retired
Been everywhere...
Reply #8 on:
November 26, 2021, 01:11:25 PM »
The OP hasn’t posted in here for a month. If he didn’t fix it he probably gave up. He didn’t seem that interested in figuring it out
