February 12, 2026, 01:36:03 PM *
Author Topic: test for fuel delivery?  (Read 2336 times)
Duffy
Atlanta, GA
« on: October 23, 2021, 01:49:48 PM »
Won't start, may not be getting fuel.. How do I determine if gas is getting to the cylinders?
Had the carbs rebuilt a couple months ago, then it sat too long again - my bad. Now it won't start. New battery, on trickle charger as needed. Turns over fine. With full choke, try's to start but won't catch on for long. Have to really work the throttle to try and keep it going.
03 Standard
Earl43P
Farmington, PA
« Reply #1 on: October 23, 2021, 02:16:35 PM »
Each carb has a drain hose.
Drain one or all, I'd drain all.
If all drain, all had fuel old fuel. Add a BIG dose of Berryman B12 Chemtool.
Retry starting, repeatedly, waiting a few moments between tries.
Check if all drain again.
If not, suspect the fuel valve and the vacuum tube that opens it.
http://www.valkyrieriders.com/shoptalk/petcock.htm
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
Duffy
Atlanta, GA
« Reply #2 on: October 24, 2021, 09:18:47 AM »
Thanks Earl, I will do that later today (off to bicycle ride now) and report back.  cooldude
Jruby38
Oxford Mass.
« Reply #3 on: October 24, 2021, 02:27:20 PM »
Ditch the OEM POS for a pingle. You will get all the fuel you can use. Cant out run it.
Madmike
Campbell River BC, Canada
« Reply #4 on: October 24, 2021, 04:56:51 PM »
OEM petcock has a vacuum line that goes to it to that opens the petcock by vacuum.  For fuel to get to the carbs the petcock needs to be in run or reserve position and the engine needs to be cranking or running to allow fuel past the petcock.  You can force the petcock open by supplying a vacuum source to the petcock via a hand pump like a MityVac or by sucking on the end of the vacuum hose and closing the end with your tongue.  If you elect the second option you should feel the diaphragm in the petcock open and then your tongue will stay pulled to the hose - like you do with a straw and a big gulp soda.
If you decide to change petcocks to a manual one you can use the K&L one which allows you to use teh OEM petcock handle on it, the petcock comes in a manual or a vacuum-operated option.
https://www.klsupply.com/carb-fuel/fuel-petcocks.asp    look at 18-4133
