February 12, 2026, 04:11:04 PM *
Author Topic: The O ring Store  (Read 2043 times)
pancho
Bonanza Arkansas
« on: November 01, 2021, 12:54:01 PM »
I'm getting ready to place an order with the O-ring store,  https://www.theoringstore.com/store/    and want to add some pilot screw o-rings to the order as I am going to be going through the carbs again sometime soon and have never replaced them.  Does anyone know the dimensions of that o-ring?  I am aware of the kits everyone, including Redeye, sells, but only require the o-rings.
I have never needed an o-ring in any common formulation that they don't have in stock, and cheap.
The cross section and the inner diameter are what I need, thanks
« Last Edit: November 01, 2021, 01:13:44 PM by pancho » Logged
ridingron
Orlando
« Reply #1 on: November 01, 2021, 06:05:50 PM »
I'm not very knowledgeable on carbs. Does this help? item 14
https://www.partsfish.com/oemparts/a/hon/5053ea2ef870021c54be3e8d/carburetor-component-parts
Savage
United States
« Reply #2 on: November 01, 2021, 07:42:02 PM »
1.3X4.3
Columbia, South Carolina
pancho
Bonanza Arkansas
« Reply #3 on: November 02, 2021, 01:56:01 AM »
That shows the part with #6 Ron, but does not give the critical data on the o-ring, thanks.
Thanks Savage, is 4.3 the ID or OD?  I don't have a free pilot screw to measure. I wonder where you got the info,,, I couldn't think of anywhere to find it.
Timbo1
Tulsa, Ok.
« Reply #4 on: November 02, 2021, 07:39:27 AM »
The dimensions were listed in the link Ridingron posted.  As to what they represent I'd guess 1.3 to be the thickness and 4.3 to be the OD
ETA: I just noticed #14 is the drain screw o-ring not the pilot o-ring.  The pilot o-ring is listed as part group #6 "Screw Set" and does not list dimensions as far as I can tell.  I remember some of the little o-rings were the same size when doing a rebuild but I don't recall which ones they were.
« Last Edit: November 02, 2021, 07:59:51 AM by Timbo1 » Logged
pancho
Bonanza Arkansas
« Reply #5 on: November 02, 2021, 08:35:44 AM »
Yeah,,  one of the reasons I asked Savage where the information came from, he may also have mistakenly seen that as the pilot screw.   Then again, they MAY be the same size?
I may just forget ordering them from the O-ring store, and order one of those cheap Valkyrie rebuild kits from eBay under the assumption that the O-rings and gaskets are Viton GF and the correct size, and see if any of the other parts are useable.    Anyone have any experience with those kits?
https://www.ebay.com/itm/185135653125?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D234506%26meid%3D4176d6b788cd41fca615b33862b5e3a9%26pid%3D101195%26rk%3D1%26rkt%3D12%26sd%3D114190727642%26itm%3D185135653125%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv9PairwiseWebMskuAspectsV202110%26brand%3DUnbranded&_trksid=p2047675.c101195.m1851&amdata=cksum%3A1851356531254176d6b788cd41fca615b33862b5e3a9%7Cenc%3AAQAGAAACEDG7Tz17%252FifVy71uaPUTcPBlUUBhqCml0bEDIMkUDZxbLUlm%252BxBxBN%252F%252BabTD474UvjlApc2W1fhWIzQ3np3Ue1Mbs3JImJt1eLmy2072tH8%252BPZnVzpZaK7MytlDUsW%252BisgggptOSEnUKud%252FFYwKPdvN%252FJFQxJfJGoGhRVVEF7ieiANoYj5QQeK1%252B1liKoersOzhBJx0gn%252BT6tpE7b5ADy%252BrUUyIu4e6gUQeBEWI%252Fx2yyccZaGyRQTfXupkUlhNQfPRu8fXHwUsA8p7jVPw56yEFGcHZFAcXgYarXGqfq2r11JzM7pDziZiTLmTCu63P5%252F0bRf9G40Tq7eoivRjKrMjSy5g9LDH6jmLWrbt8LjlNxkezr2Q0snmowgIj41%252FDGDpJ%252B47lM8tFDbyFeCPrBOV0OsFVTRmyfK8Lruhfyjhz719ESXmy8Gtgvr1zMzsV%252Ftd%252BlkzuLdZcbsoMtwN6Mmyn8YEu2EbwjIJB03%252B9qH6k2ixyEBTYsN8%252FLd62QZOt42uxeyIPJIlCEi4i6WRZjnhycqgoHhrNqSTh9sbbMREz2t00lxZCbWoHnPU1bgfg%252B7PXEGqcF8RdS3vIt7DQ8iED2ujX1qEBpB5B4lY4ZwJh1DLWeQFAnUWTKzjoCDXCgKsmGzcVP523BPgjncO5eUPoFJvrpJsgsaTjSjXPx3TX050wI%252BmfjiNn43I7ggybGuQ%253D%253D%7Campid%3APL_CLK%7Cclp%3A2047675
Timbo1
Tulsa, Ok.
« Reply #6 on: November 02, 2021, 08:43:46 AM »
So I went out and started digging in my parts bin and found a old pilot screw and o-ring.  While the o-ring is flattened from being old I think I have fairly close measurements for you to go off of.
Pilot screw OD is 3mm
O-ring OD is 5mm
O-ring Cross Section is 1.0 - 1.3mm
So if the Pilot Screw OD is 3mm the o-ring needs to be 3mm ID by 5mm OD,  That leave for 1mm cross section.
If I were going to order some I'd probably go with 1-1.2mm cross section by 5mm OD.  I'd probably lean more toward 1.2mm just to make it a little tighter but they're probably cheap enough you could order a variety of sizes for a few bucks.
Timbo1
Tulsa, Ok.
« Reply #7 on: November 02, 2021, 08:54:07 AM »
Yea I ordered an Ebay kit and found nothing fit other than the drain screw o-ring.  Jets were wrong, needles were wrong, Bowl seals and vacuum chamber seals wrong literally everything was wrong.  Wasted a week of my time dealing with that.  After that I ordered All Balls kit from Amazon and haven't looked back.  Ordered a second set for another bike same year and both kits were perfect.  Sometimes trying to save a little money ends up costing me a lot of time. lol
pancho
Bonanza Arkansas
« Reply #8 on: November 02, 2021, 09:10:47 AM »
Appreciate the heads up on the eBay kit,, I don't need the wasted time.
Adding to the O-ring store order leaves a lot of choices although inexpensive.
https://www.theoringstore.com/store/index.php?main_page=index&cPath=368_12_36
Red eye still shows some pilot screw kits in stock, or I may just do an All Balls kit and be prepared.
Thanks Timbo
Savage
United States
« Reply #9 on: November 03, 2021, 04:00:09 AM »
Apologies, it appears I read & listed the wrong size for that o-ring.
Thanks for the correction.
