February 12, 2026, 09:12:13 AM *
Author Topic: Wheel Bearing Dust Seal  (Read 1833 times)
Knapdog
South Wales, UK
« on: November 29, 2021, 03:41:19 AM »
As recommended in Shoptalk, I've purchased one of these. I didn't think it was particularly cheap at nearly £16 inc postage, but there you go.
Now that I've had the wheel off I can't see anything wrong with the old one, tbh.
If I decide to put the new one on, how do I get the old one off? I don't want to start gnashing it with a screwdriver just yet.
Stay between the hedges!
'98 Honda Valkyrie Tourer⁸
'96 Honda C90
'83 Honda C90C
Earl43P
Farmington, PA
« Reply #1 on: November 29, 2021, 04:26:16 AM »
I do use a wide flat screwdriver to gently pry that out. Not much friction holding that seal in.
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
Jims99
Ormond Beach Fl.
« Reply #2 on: November 29, 2021, 04:51:44 AM »
Yes, put the screw driver blade between the bearing and seal and work your way around slowly. They usually come out pretty easy.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Knapdog
South Wales, UK
« Reply #3 on: November 29, 2021, 05:00:22 AM »
Thanks, folks.  'Twas all I needed to know.
Should I grease the new one before inserting or is it best placed with the outer part dry?
« Last Edit: November 29, 2021, 08:12:53 AM by Knapdog » Logged
'96 Honda C90
'83 Honda C90C
« Reply #4 on: November 29, 2021, 11:37:47 AM »
I wouldn’t change it. Instead by a set of bearings to have on hand. They don’t come with the dust seal. Change the seal when and if you change the bearings
Knapdog
South Wales, UK
« Reply #5 on: November 29, 2021, 11:52:07 AM »
Problem is my inquisitive screwdrivers have already started greeting the Seal and have become very well acquainted with it.  Smiley
'96 Honda C90
'83 Honda C90C
Jims99
Ormond Beach Fl.
« Reply #6 on: November 30, 2021, 05:20:44 AM »
I have always put a very light coat of grease on the outer part to help it slide in without damage.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
