« on: December 07, 2021, 04:54:49 AM » |
GOOD MORNING VRCC  Pain pills are working good. I’m a couch potato so if you are working on your Valkyrie or planning on it and you need advice you can call. I can talk you through, take pictures of my parts/assembly if needed or talk you out of it. Lol. Things I have done a lot of: Alternator R/R Wheel R/R front and back Tank removal Valves Timing belts Fork leaks Brakes/Hydraulic bleeding Cleaning tips Posting pictures PM me or call at 850 eight 65-five378 My cell is also my business phone so I’ll probably answer “Hello, Wood Perfect “ You won’t be bothering me you will help me from going nuts sitting here
« Last Edit: December 07, 2021, 06:06:37 AM by Chrisj CMA »
« Reply #1 on: December 07, 2021, 04:59:15 AM » |
I'm stoned on pain pills, call me for advice on how to work on your bike...  -Mike "just plug it in anywhere, it doesn't matter!..." PS. Glad you're OK...
6adan
« Reply #2 on: December 07, 2021, 05:03:15 AM » |
That is great of you. It will help people who need help and you to keep your mind busy. I know it is best for me to help and be helped by talking.
1970 CB750JDM, 1975 GL1000, 1979 GL1000 semi cafe, 1979 CBX, 1995 GL1500 SE, 2008 GL1800 trike. Several more not running yet.
« Reply #3 on: December 07, 2021, 05:07:47 AM » |
I'm stoned on pain pills, call me for advice on how to work on your bike...  -Mike "just plug it in anywhere, it doesn't matter!..." PS. Glad you're OK... Lol Mike. Didn’t think of it that way. I take minimal pain meds. People need not worry. I’m not stoned. But that was a valid observation. Thanks
Mooskee
« Reply #4 on: December 07, 2021, 11:51:10 AM » |
Chris, Hope you heal fast.
Avanti
« Reply #5 on: December 07, 2021, 03:59:12 PM » |
The only winterized motorcycle in Florida.
« Reply #6 on: December 07, 2021, 04:13:13 PM » |
Lol. But not for the WHOLE winter
RonW
« Reply #7 on: December 07, 2021, 06:08:39 PM » |
been there. don't over eat or under eat.
2000 Valkyrie Tourer
Steel cowboy
Spring Hill, Fl.
« Reply #8 on: December 07, 2021, 07:37:45 PM » |
Get well soon.
2001 black interstate 2003 Jupiter Orange wing
Grey wolf oz
« Reply #9 on: December 08, 2021, 01:53:21 AM » |
GOOD MORNING VRCC  Pain pills are working good. I’m a couch potato so if you are working on your Valkyrie or planning on it and you need advice you can call. I can talk you through, take pictures of my parts/assembly if needed or talk you out of it. Lol. Things I have done a lot of: Alternator R/R Wheel R/R front and back Tank removal Valves Timing belts Fork leaks Brakes/Hydraulic bleeding Cleaning tips Posting pictures PM me or call at 850 eight 65-five378 My cell is also my business phone so I’ll probably answer “Hello, Wood Perfect “ You won’t be bothering me you will help me from going nuts sitting here Swift recovery !
RonW
« Reply #10 on: December 08, 2021, 03:18:26 AM » |
Hi Chrisj CMA, perhaps, you'd like to field some Q & A on this thread. I've been going over your Power Point presentation on the Rear Wheel Service.You advised that nothing is gained by overtightening the right shock lower bolt and the caliper plate holding bolt ..... "just snug them up as tight as a spark plug." However after checking the torque spec for the caliper plate holding bolt, I found the torque value stated as 51 ft-lbs in the manual. Not trying to nitpick but with a 51 ft-lbs torque spec, tightening this bolt the same as a spark plug would undertighten bolt.   The threaded section on the stopper bolt screws into a steel boss in the swingarm such that there is no aluminum to steel connection as it would be the case if the stopper bolt was threaded in the aluminum caliper bracket. Neither a significant risk that 51-ft lbs would strip the threads as long as care is exercised.   Btw, does the slot make it possible to position the rear brake caliper bracket incorrectly? I never noticed the slot until I saw the pics but everything went well with my rear wheel installation.
« Last Edit: December 17, 2021, 04:39:00 AM by RonW »
« Reply #11 on: December 08, 2021, 04:45:50 AM » |
I do not think that “slot” can allow a miss alignment of the caliper plate. If you draw an ark that runs through the “slotted hole” with the center of the arc being the axle the slot does not follow that arc so there will be very limited slop or movement.
As far as torque on those to bolts. As stated, they are just pins. 51 lbs is way over kill. So long as they don’t loosen they will do the same job at any torque setting. I probably torque them to 10-15 lb. if you ever had a stuck caliper plate pin/bolt you will be careful with it
« Last Edit: December 08, 2021, 07:06:40 AM by Chrisj CMA »
RonW
« Reply #12 on: December 08, 2021, 04:55:36 AM » |
okay
« Reply #13 on: December 08, 2021, 05:16:44 AM » |
I've seen the threads that lower shock bolts screw into stripped out, maybe from over tightening, maybe from trying to replace the bolt while there was weight on the rear wheel. I jack my bike until the wheel is barely resting on the ground to remove the lower shock bolts, once they break free you can screw them out by hand, and when you put them back in you can screw them all the way in back in by hand. No tension or compression on the shocks...
« Reply #14 on: December 08, 2021, 05:19:18 AM » |
Yes start byhand
« Reply #15 on: December 08, 2021, 05:51:19 AM » |
I'm stoned on pain pills, call me for advice on how to work on your bike...  -Mike "just plug it in anywhere, it doesn't matter!..." PS. Glad you're OK... Lol Mike. Didn’t think of it that way. I take minimal pain meds. People need not worry. I’m not stoned. But that was a valid observation. Thanks I wouldn’t hesitate to ever call you for advice on a Valkyrie. (Unless you were all hopped up on them OxyContin things)  This is kind of personal, but I missed what kind of surgery you got ? No more pain pills. You didn’t miss the surgery
« Reply #16 on: December 08, 2021, 07:13:13 AM » |
Just to clarify what I was thinking. The red arc with arrows show the direction of motion that the plate can move once the axle is installed. So that slot is not going to allow misalignment
RonW
« Reply #17 on: December 08, 2021, 02:39:21 PM » |
roger dat.
pancho
« Reply #18 on: December 08, 2021, 03:59:17 PM » |
Hey Jeff a couple of us are wondering about the surgery you mentioned... is this something to do with your shoulder that got torn up a few years ago?
« Reply #19 on: December 08, 2021, 05:10:44 PM » |
Ok, no. I hadn’t shared because it’s kinda gross. It was a multiple hemorroidectomy. A royal PITA and not really any fun at all to be honest. And no! No pictures
pancho
« Reply #20 on: December 08, 2021, 06:18:51 PM » |
WHOA, I had to ask!!!! won't get that picture out of my head for awhile.
I said a prayer for you brother, hope your back in the saddle soon.
« Reply #21 on: December 09, 2021, 05:11:11 AM » |
Mike, the way I remove the right side shock : Put the bike on the lift. Second catch Remove top bolt first and dismount shock from the upper post Now there is no pressure on the lower bolt
Bagger John - #3785
« Reply #22 on: December 09, 2021, 03:29:39 PM » |
When I put those pins back in, I use a dab of Anti-Seize and de-rate the torque spec accordingly (~5% in terms of noted ft/lb values). The shock pin gets a coating of high-temp silicone grease too.
Never had one give me problems coming back out.
I HAVE seen people experience issues with the brake stopper pin because some "mechanic" thought that Unified National Cross-Thread is the proper approach to take with ALL fasteners.
Start by hand, snug by hand. If the pin bottoms without resistance you may then apply the wrench.
« Last Edit: December 09, 2021, 03:31:39 PM by Bagger John - #3785 »
« Reply #23 on: December 09, 2021, 03:48:12 PM » |
Yes. I believe in the anti seize for those two bolts for sure.
RonW
« Reply #24 on: December 09, 2021, 07:00:51 PM » |
reinstalling the shocks, I found that installing the lower bolt before the upper bolt makes it easier to pull the shock to make it a little longer or compress it a smidgen. Albeit, I don't have the shocks on the stiffest setting.
« Reply #25 on: December 09, 2021, 11:03:46 PM » |
Yep, totally agree. Especially the right side. It takes forever to get the holes lined up for the bottom bolt if its already on its upper mount
Bagger John - #3785
« Reply #26 on: December 10, 2021, 05:24:43 AM » |
Yep, totally agree. Especially the right side. It takes forever to get the holes lined up for the bottom bolt if its already on its upper mount I have a couple of screw jacks that come in handy for raising the final drive unit just enough to line things up.
« Reply #27 on: December 10, 2021, 05:51:24 AM » |
Yep, totally agree. Especially the right side. It takes forever to get the holes lined up for the bottom bolt if its already on its upper mount I have a couple of screw jacks that come in handy for raising the final drive unit just enough to line things up. That works as long as the axle then the four final drive bolts are all torqued before you jack up the final drive
RonW
« Reply #28 on: December 10, 2021, 06:06:29 AM » |
that's why these thingies are handy installing the axle and 4 bolts. The thingie is on the left side of the bike and don't get in the way of work on the right side while allowing wiggle room for the right side swingarm.
« Last Edit: December 17, 2021, 04:47:10 AM by RonW »
Bagger John - #3785
« Reply #30 on: December 10, 2021, 07:59:44 AM » |
I follow the service manual procedure for this: Final drive is positioned onto the swing arm (w/ drive shaft engaging U-joint) and the case mounting bolts are put loosely onto the studs. Jack is applied underneath the case (if needed) to line the shock bushing collar up; pin is inserted. Final drive nuts are torqued, the wheel and brake backing plate installed then the axle torqued. Lastly, the shock pin is torqued. The wheel is checked for binding and free rotation before the bike comes down off the lift and the pipes are re-installed. Yes, I follow that part of the manual as well. It gives me the opportunity to clean and inspect sections of the exhaust which are normally inaccessible.
« Reply #31 on: December 10, 2021, 08:13:00 AM » |
Well keep doing what works for you but that procedure is not by the book. Proper final drive alignment happens when the axle is torqued while the four bolts are still loose. I’d rather not even have the right side shock on to impede the alignment process
Bagger John - #3785
« Reply #32 on: December 10, 2021, 08:32:35 AM » |
1997-2001 Service Manual. Section 12-3, "Final Drive Removal" and Section 12-18 to 12-19, "Final Drive Installation". Yes, what I laid out most certainly IS by the book. FWIW, I double-checked the manual before my original comment just to be certain the process is as I've been describing.
« Last Edit: December 10, 2021, 08:37:52 AM by Bagger John - #3785 »
« Reply #33 on: December 10, 2021, 08:54:52 AM » |
Like I said do what works for you. If the procedure you described is by the book it’s not the Honda book and I would not recommend that procedure. Honda book  Correct sequence
Bagger John - #3785
« Reply #34 on: December 10, 2021, 09:00:46 AM » |
Look up the term "superceded". Mine's a later manual than yours. Things (and processes) change.
« Reply #35 on: December 10, 2021, 09:05:39 AM » |
 Clearly the axle is tightened before the four nuts. Torquing the four nuts before the axle makes no sense and obviously thereby removes the mechanism for final drive to wheel alignment. I’m not going to argue with you but four bolts then axle is a guess at alignment and not reliable
« Reply #36 on: December 10, 2021, 09:18:21 AM » |
Here’s the glitch. Yes the book says to install the drive as you said on pp 12-18. However, it also says install wheel pp14-8
When you get to the wheel installation it directs you to loosen the four nuts. You have to add both sections together
Bagger John - #3785
« Reply #37 on: December 10, 2021, 09:19:12 AM » |
Just going on what my manual states here. What I suspect is that the procedure was changed to make the final drive the "reference" by which the other parts are pulled into alignment.
I've done it both ways and FWIW can detect absolutely no difference in play, rotational freeness (or impediment), alignment...tire wear. My litmus test is a freely rotating, non-binding wheel. If the parts are aligned and tightened properly, there should be little or no rotational resistance observed.
ETA:
Your comments above make sense, though you'd think the proof readers would have caught this.
« Last Edit: December 10, 2021, 09:20:43 AM by Bagger John - #3785 »
« Reply #38 on: December 10, 2021, 09:38:15 AM » |
ETA:
Not arguing simply discussing. Once the axle is through the wheel the alignment of the wheel cannot be altered. Once the four nuts are loosely installed there is significant play rotationally for the drive on the swing arm flange. So that being true, it only makes sense that the wheel is the primary reference and the drive must me “told” to marry up with the wheel. This only happens when the axle is torqued while the dive can still move.
« Reply #39 on: December 10, 2021, 10:05:48 AM » |
By combing over these pages I think I know why the writers did it this way. The shock sets the altitude. The axle sets face to face alignment It might be better to install the shock with the lower bolt loose before the torquing sequence. But the axle still will get torqued with the four nuts loose.
Added: in my case since I don’t remove the exhaust I would need to:
Torque the axle then install shocks, left first then right leaving the bottom bolt loose and then the four nuts followed by the lower shock bolt. I’ll have to ponder this.
« Last Edit: December 10, 2021, 10:32:43 AM by Chrisj CMA »
