February 12, 2026, 11:11:40 AM *
Author Topic: Big BF Quad Horns Installation.  (Read 2829 times)
Mooskee
Southport NC
« on: December 07, 2021, 06:00:51 PM »
I have a set of Big BF's Quad hornes. I got them in a parts trade, and have never had them installed. Two of the horns were bad, so I replaced them, and am building a horn relay wiring harness for them. I plan to sell them, but would like to be able to supply any installation instructions Big BF had. I dont need instructions for the horn relay, Just for the mounting.
There is an X brace with the horns on it and a heavy arm with a bolt hole in it comming off the middle of the X brace. What do these bolt to under the bike? Are they compatable with a Rivco Center Stand?
TIA
Mooskee
Southport NC
« Reply #1 on: December 07, 2021, 06:50:38 PM »
Thanks. Pretty strait forward then. I Figured it couldn't betoo bad with just 1 bolt. It does help if you know which bolt!
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: December 07, 2021, 07:32:29 PM »
I thought they mounted to the flat part of the swingarm. I can't post pictures here, but if you want to text me I can send some pics from under my bikes. My cell is 8zero6665nine144
Mooskee
Southport NC
« Reply #3 on: December 08, 2021, 05:55:59 AM »
My network seems to think that is a land line.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #4 on: December 08, 2021, 06:35:41 AM »
Message me your cell number and I’ll just send them.
SCain
Rio Rancho, NM
« Reply #5 on: December 08, 2021, 06:45:36 AM »
If I remember correctly they bolt to the little cross frame, where the kickstand bolts to. They don’t work with the center stand. But, I’m sure you could split them in pairs and fit them down there.
Rob is correct, the kickstand cross member, if its a 1 bolt bracket, there is a clip with threads on the top and a single bolt from the bottom, this was Bills newer design.
The older style bracket is a two piece with two bolts.
Steve
Mooskee
Southport NC
« Reply #6 on: December 09, 2021, 08:40:54 AM »
Yes, it is the one bolt bracket. Thanks Guys. I appreciate the info.
Jruby38
Oxford Mass.
« Reply #7 on: December 09, 2021, 07:17:15 PM »
I have a new dual horns for a Dodge Ram, same that is on my truck. Will wake the dead loud but I dont see a way to mound them.
Anyone know how mount auto horns?
« Reply #8 on: December 10, 2021, 04:18:45 AM »
BigBF Quad Horns are four car horns on a easily
made bracket. Here's a "sort of" picture of mine I
took when I got done cleaning up the mess from when
my slave cylinder went kablooie. I replaced my original
quad horns with four new car horns from NAPA when
I was refurbishing the clutch slave.
Other people probably have pictures of their quad horn
mounts. The mount is just a couple of little pieces of
flat bar. Of course BigBF figured out the details of how
to bend and cut each piece, you'd have to do that.
Jruby38
Oxford Mass.
« Reply #9 on: December 10, 2021, 09:47:13 AM »
What electric plug connector do you use with a  car horn? The Ram duel horn setup has one plug and it doesn't match the Valk. I don't need quads, these duals are loud enough.
« Reply #10 on: December 10, 2021, 10:26:38 AM »
I don't know the answer to your question, but I don't
think it matters. You wouldn't want to hook a bunch
of car horns onto the wire that runs the OEM beep-beep
horn. I use the OEM horn wire to trigger a relay for my
horns.
Mooskee
Southport NC
« Reply #11 on: December 14, 2021, 12:27:05 PM »
horns.
I just drew this horn relay schematic for the set of Big BF Horns I am selling. I made up the wiring harness with several options, but you can make yours for your specific application. If you have any questions feel free to ask. I might even be persuaded to build you a relay harness for a small fee.
The idea is to utilize a relay to operate the horns, which will limit the current on the horn switch. Instead of having the current of multiple horns on the horn switch, we will only have the current to pick up a small relay. The relay contacts will use an alternate source of power to operate the horns, and can handle up to 30 Amps. The diode across the relay coil is a flyback diode to keep inductive kick from arching across your horn switch.
lostparrot
Northern IL
« Reply #12 on: December 18, 2021, 12:49:23 AM »
I have a set on my 97 with a Rivco centre stand. When I get home I can take a pic of you need me to.
cheeseman1969
Hastings NE
« Reply #13 on: December 20, 2021, 04:25:17 PM »
Very interested in this. I am wanting to have more uumfff in the honks. You just got 4 car horns and then connected them together. Of course more to that. But following.
Gary "Cheeseman"
USN "weather guesser" Retired
Been everywhere...
« Reply #14 on: December 20, 2021, 05:07:03 PM »
Most (all?) of the more is that BigBF already figured out the dimensions
of the little bracket and where/how to mount it. I'd had mine since the 2nd
Johnson City InZane, and they were getting tired. I changed out the car
horns with some from NAPA this summer. LOUD  smitten ...
mello dude
Dayton Ohio
« Reply #15 on: December 21, 2021, 08:36:01 AM »
Do wire the horns in series or parallel?
Mooskee
Southport NC
« Reply #16 on: December 21, 2021, 10:46:06 AM »
Parallel.
