January 30, 2026, 06:33:15 AM *
Author Topic: bag guards  (Read 2814 times)
« on: January 18, 2010, 12:37:07 PM »
Can anyone post a picture of where the oem bag guards hook up on a tourer?  where do they bolt on at the front and rear?  It would be very much appreciated.  Hoser
MP
North Dakota
« Reply #1 on: January 18, 2010, 08:43:03 PM »
hoser:
One goes on the top shock bolt.  One goes below on the front bolt where the bag mounts go,  and I need to look where the back one goes! One goes under the bag mounts, and you use a longer bolt where the rear bolt is in the bag.  You need washers or a spacer on that one, then a nut.  LOL  Same on IS as std.
I will try to get a pic tomorrow.
MP
"Ridin' with Cycho"
woefman
Arizona
« Reply #2 on: January 18, 2010, 09:23:00 PM »
I too was going to try and get you a photo , but I can barley see my Valk at this point.
Too many Projects going on.
Will see if I cant clear a path this week , but someone may beat me too it ...if so sorry .
Honda` GL1800 Goldwing
Honda` GL1500 CT Valkyrie
Picture Links below:
http://picasaweb.google.com/azpicts
and
http://picasaweb.google.com/azpicts2
TomL
Sunbury, Ohio
« Reply #3 on: January 19, 2010, 02:26:25 AM »
No pic, but I believe you can go to the shoptalk link/page and there are instructions for the OEM Hondaline bag rails with good graphics.  Hope this helps you.
Tom
"The first hundred years is the hardest"   Will Rogers
« Reply #4 on: January 19, 2010, 03:10:45 AM »
« Reply #5 on: January 19, 2010, 05:36:26 AM »
Okay, now I get it.  Much thanks!  cooldude hoser
MP
North Dakota
« Reply #6 on: January 19, 2010, 06:21:27 AM »
good pics,  you need a longer bolt on the lower front attach point, and you need to remove the u shaped rear barn and replace with a piece that has a T instead of elbow. You can see it in the pics.
MP
"Ridin' with Cycho"
« Reply #7 on: January 19, 2010, 08:23:16 AM »
How does it work with a hitch? I wonder if the ebay oem versions will work with a hitch? I ain't spending a $1000 on a oem set. I had MC Ent but removed them cause the hitch was in thw way. I know Painter and Po has a set on there bike tho.
MP
North Dakota
« Reply #8 on: January 19, 2010, 08:50:54 AM »
Look at hubcapsc's pics.  The one on the bike shows a hitch on the bike, so yes, a hitch can be used with the OEM Hondaline saddlebag guards!  Thanks, hubscapsc, I was wondering that too!
MP
"Ridin' with Cycho"
« Reply #9 on: January 19, 2010, 08:54:26 AM »
MP
I think I have those pictures because those are the rails I bought several years ago. I'm looking at that picture now, the bags, the rails, the
fender extender, the radio, the hitch... I'm glad I don't have to change the rear tire on that bike!  Smiley
« Reply #10 on: January 19, 2010, 09:47:52 AM »
How do they fit with the hitch? With my hitch I was unable to use the chrome bar that is behind the tire.I had to make one to put back on my SB supports. It was about a inch wider then the oem bar. My hitch had no spacers so I had to find my own. Maybe I got to long of ones. Wonding if it would change how the sb gaurds fit.
