February 12, 2026, 05:00:08 AM *
Author Topic: Car air shocks on a Valkyrie - Why Not  (Read 3225 times)
mrtlc
Elroy WI
« on: May 05, 2022, 08:44:05 AM »
I put a set of Monroe air shocks on my bike. A little adapting, but seem to fit nice. Is there any reason not to try this? Motorcycle air didn't have enough capacity. These are rated for 150psi. Let me know if there could be a problem!
99 Interstate 1500
89 Goldwing sidecar 1500
88 Goldwing 1500
85 Goldwing 1200
84 Gold wing 1200
80 Goldwing 1100
79 Yamaha XT500
78 Honda 750K
« Reply #1 on: May 05, 2022, 09:23:57 AM »
You let us know!  A+ for innovation!   cooldude
Pictures?
« Reply #2 on: May 05, 2022, 09:56:15 AM »
Just spit-balling here, but it would seem to me shocks designed for car weights might be stiff as hell for bike weights.
But if they can be adjusted way down, who knows?
DragonRdr
Gardner, MA
« Reply #3 on: May 05, 2022, 10:08:47 AM »
Are you going to go Darkside on the rear tire?  Evil Seems like the next logical step if the shocks work out. Good luck  cooldude
2000 Valkyrie Interstate
1994 Goldwing Interstate
mrtlc
Elroy WI
« Reply #4 on: May 05, 2022, 06:29:57 PM »
Dark sided for years  ready.
99 Interstate 1500
88 Goldwing 1500
85 Goldwing 1200
84 Gold wing 1200
80 Goldwing 1100
79 Yamaha XT500
78 Honda 750K
Avanti
Stoughton, Wisconsin
« Reply #5 on: May 05, 2022, 07:46:52 PM »
Which Monroe shock did you use?
mrtlc
Elroy WI
« Reply #6 on: May 06, 2022, 06:54:00 AM »
MA785
99 Interstate 1500
88 Goldwing 1500
85 Goldwing 1200
84 Gold wing 1200
80 Goldwing 1100
79 Yamaha XT500
78 Honda 750K
« Reply #7 on: May 06, 2022, 07:27:42 AM »
Looks like some of the HD guys have tried it.
« Last Edit: May 06, 2022, 07:31:05 AM by Valkorado » Logged
Timbo1
Tulsa, Ok.
« Reply #8 on: May 06, 2022, 11:58:24 AM »
My brother has Monroe air shocks for a 63-64 Corvette that he replaced his OEM air assist shocks with on his Road King.  Says they're great.  Seems they're the same shock that was put on the 2015 Road Glide which is what my son has.
Avanti
« Reply #9 on: May 06, 2022, 12:15:57 PM »
MA785 Monroe air shocks fit 63-82 Corvette.
Bagger John - #3785
« Reply #10 on: May 06, 2022, 12:58:43 PM »
I may look into a set of these for my blacked-out Supervalk. It already has a custom compressor/bleed system for its 416 Progressives.
« Reply #11 on: May 06, 2022, 03:42:32 PM »
What and how did you do the mods?
We need pics Wink
Bret SD
San Diego, Ca.
« Reply #12 on: May 07, 2022, 04:36:37 PM »
Looks like it would be easy enough to do, the modifications needed are minimal. I may do this at some point as my rear shocks are getting tired. I'll likely mount an air fitting in the trunk and throw a little more air in when riding 2 up. This video is about the way I had planned, a portable compressor and cigarette lighter in the trunk near the fitting would be easy and convenient for on the road adjustments.
https://www.youtube.com/watch?v=Kwz9imRF_9k
Bret
02 Standard -- Blue & White
82 Aspencade -- Red
mrtlc
Elroy WI
« Reply #13 on: May 09, 2022, 11:00:41 AM »
The lower mounts had to be narrowed about a 1/8 of an inch. The top rubber mounts had to be drilled out with a 3/4 step bit to install the right size steel bushings. I left the top mounts the bigger size, used longer bolts and cut the bushings to the right length. Changed the bushings with a vise and assorted sockets. I finally got my air lines today. Will report back on how it works.  If it works on a Harley, should be awesome on a Valkyrie  :-).
Fleet farm seems to be the best price. They had a 50 percent off sale. $38
99 Interstate 1500
88 Goldwing 1500
85 Goldwing 1200
84 Gold wing 1200
80 Goldwing 1100
79 Yamaha XT500
78 Honda 750K
mrtlc
Elroy WI
« Reply #14 on: May 09, 2022, 08:57:47 PM »
After I got the air leaks stopped. They worked out great. With almost 600 # of big boys on the bike it only cuffed the tire slightly going over a RR track marked with a bump sign. Had the shocks set at 110 psi, they can go to 150. So far I'm very happy. I'm also running a tall Austin tire on the back.
99 Interstate 1500
88 Goldwing 1500
85 Goldwing 1200
84 Gold wing 1200
80 Goldwing 1100
79 Yamaha XT500
78 Honda 750K
Kep
My "Mid-life Crisis "
Indiana
« Reply #15 on: May 13, 2022, 06:32:50 AM »
How did you get 50% off ??
Pappy!
Central Florida - Eustis
« Reply #16 on: May 13, 2022, 06:05:39 PM »
I bought a bunch of parts for Valks from a couple that had sold their Valks. In the pile is a brand new pair of air shocks. Size wise they look like a perfect fit. Did not look at the mfr.
