February 12, 2026, 03:01:00 AM *
Author Topic: New car tires? LIke the more aggressive look and rounded profile.  (Read 2760 times)
Pappy!
Central Florida - Eustis
« on: May 11, 2022, 09:15:18 AM »
Any nice looking new car tires out there these days? May install a new one prior to Inzane.
« Reply #1 on: May 11, 2022, 09:47:39 AM »
A few are using a Achilles ATR Sport
On my 1500 I really liked the Champiro VP1.
BUT the best I got was about 15,000 miles.
« Reply #2 on: May 11, 2022, 10:52:53 AM »
Here's a couple I've saved from previous posts here (I might use when I need one).
https://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=CrossClimate%2B&sidewall=Blackwall&partnum=06VR6CCPXL&tab=Sizes
https://www.michelinman.com/auto/tires/michelin-crossclimate2
TrapperAH1G
Toledo, WA
« Reply #3 on: May 11, 2022, 05:44:54 PM »
I run DS on 2 of my bikes.  Zeetex CT1000, and a Vredistan (sp?) Comtrac.  The Comtrac is the replacement of the Austone.  Of the 2, the Zeetex is by far my preferred tire.  I have 10K on it and NO sign of wear.  Only have 5K on the Comtrac, no wear showing.  Both mine are 185/75-16.  Lowers the asphalt rpm some, not much.
Seen lots of nice looking tires, I just can't find them in the 185 width much.  I don't want to go any wider than 195, and that size only if I have no choice.  To each their own.
Pappy!
« Reply #4 on: May 11, 2022, 09:43:25 PM »
I currently run a Vredestein although an older one in excellent shape. very aggresive look and a wonderful rain tire. Only reason I may change is the age of that tire even though it shows no weathering signs at all.
Jess the first link looks like it is only available in a 15" tire.
0leman
Klamath Falls, Or
« Reply #5 on: May 13, 2022, 07:53:09 AM »
I have a Zeetex CT1000 on right now.  Some 6K miles.  Looks like it has never been on the road, and I ride mostly on ChipCoat roads which eats tires.  Yes, it is a light truck tire.  It is in the 195/65 size. Will probably buy another one when this one wears out.
Pappy!
« Reply #6 on: May 13, 2022, 02:54:57 PM »
Bought another Vredestein. I like the one I already have and this replacement looks good as well.
This tire weighs 17# as well so it will free up some power and fuel mileage hopefully. some I looked at were around 21-22#.
I am trying the 195/65R16 this time as well. The 205 was a super tight fit.
https://www.tirerack.com/tires/tires.jsp?tireMake=Vredestein&tireModel=Quatrac&partnum=06HR6QTXL&vehicleSearch=false&fromCompare1=yes
note the tire in the link is a 205.
Pappy!
« Reply #7 on: May 14, 2022, 01:52:16 PM »
Old Vredestein
New Vredestein
« Last Edit: May 14, 2022, 02:53:58 PM by Pappy! » Logged
6adan
Zip City, Alabama
« Reply #8 on: May 15, 2022, 06:23:06 AM »
Pappy, where did you get that dark side sticker?
1970 CB750JDM, 1975 GL1000, 1979 GL1000 semi cafe, 1979 CBX, 1995 GL1500 SE, 2008 GL1800 trike. Several more not running yet.
Pappy!
« Reply #9 on: May 15, 2022, 05:14:05 PM »
I believe TJ had them....may still have some.
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #10 on: May 15, 2022, 05:39:16 PM »
Kumho Ecsta PA31   on my Valk:
Yokohama Avid Envigor Z.P.S on my F6B
The Yokohama is a run flat and I love it. Best Dark Side tire I have tried.
2013 Black and Red F6B (Gone)
2016 1800 Gold Wing (Gone)
1997 Valkyrie Tourer
2018 Gold Wing Non Tour
Avanti
Stoughton, Wisconsin
« Reply #11 on: May 15, 2022, 05:43:41 PM »
Yokohama Avid Envigor a great tire but unfortunately it has been discontinued.
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #12 on: May 15, 2022, 06:37:34 PM »
Crap, I didn't know that. I got mine last October. Just like the Michelin Alpin, I liked that too and it was discontinued also.
« Reply #13 on: May 15, 2022, 06:59:28 PM »
I thought that run flats had to ride harder because of the stiff sidewall.  Does it?
(otherwise, it seems like a very good idea, and that is a good looking tire)
« Last Edit: May 15, 2022, 07:01:07 PM by Jess from VA » Logged
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #14 on: May 16, 2022, 02:33:49 PM »
It doesn't seem to me to ride any harder than the other dark side tires I have used. It's my third run flat and I run it about 32 PSI considerably less than I have run in my non run flat tires.
Jim in Idaho
« Reply #15 on: May 26, 2022, 08:07:34 AM »
Yokohama Avid Envigor   205/60R16  92V
rumors of it's demise have plagued the internet for the past two years but they keep coming back in stock at SimpleTire.   Ordered this Tues (5/24)  Shipped Wed. (5/25)
NOTE:  this is NOT the ZPS option
Love this tire!!
Jim in Idaho
https://simpletire.com/brands/yokohama-tires/avid-envigor#v=1&tireSize=205-60r16&mpn=110132122&stmodel=avid-envigor&stcategory=all-season&sttype=passenger&utm_source=google&utm_medium=cpc&utm_campaign=G_Shopping_Region_10&utm_content=Passenger_Competitive_LowProfit&utm_term=&utm_creative=378241177642&gclid=CjwKCAjw5fzrBRASEiwAD2OSVzYDR63I3vDwcyRIw7q3UTv2shOPXhfxWY08mWUJ-ehZoLhSPQKBuxoCxesQAvD_BwE
Pappy!
« Reply #16 on: May 26, 2022, 05:34:00 PM »
Finally had a chance to ride my new rear tire. A Vredestein Quatrac from Tire Rack.
After a few car tires on the back I have to say this is by far the best of the bunch! You don't even know you are on the dark side. Rolls into a corner as if it was meant to be on a bike instead of a car. Quiet as a mouse and super smooth. Pressure is at 35psi right now for starters.
Ken aka Oil Burner
Mendon, MA
« Reply #17 on: May 27, 2022, 03:38:20 PM »
Hey Pappy. I saw you post that you ordered a 195-65-16, but I only saw a 195-60 available at Tire Rack. Is that the size you ended up getting, or is yours in fact a 195-65? That's the size I had planned on, but if the 195-60 is that good, I may go that route. Thanks for the update.
Pappy!
« Reply #18 on: May 27, 2022, 08:19:40 PM »
Yep.....it is a 60! My bad.....
Second Vredestein now and I really liked the first one but could feel that break over as you roll into a turn. With this one the transition into a turn is silky smooth.
Ken aka Oil Burner
Mendon, MA
« Reply #19 on: May 27, 2022, 08:40:43 PM »
Nice. Thanks again for the update.  cooldude
