February 12, 2026, 05:00:13 AM *
Author Topic: Temperature Indicator light flashes  (Read 1343 times)
Tato
Lloydminster, Alberta, CANADA
« on: May 18, 2022, 12:20:23 PM »
Hi, everyone!
My temperature indicator light started flashing recently, it flashes randomly but does not stay on...I can hear the fan kick in and i recently replaced the coolant...
I am not mechanically inclined but from what i have read it could be the Temperature sensor or the thermostat....any suggestions or ideas?
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: May 18, 2022, 01:04:23 PM »
My assumption is yours is prior to a 2000 model. Those sensors sometimes do that. There is a work around somewhere on this site. I just ignore mine.
Rosie
Clintonville WI 54929
« Reply #2 on: May 18, 2022, 03:56:09 PM »
Mine did the same, search intermittent cooling light.
1999 Valkyrie tourer
2003 Valkyrie standard
Tato
« Reply #3 on: May 18, 2022, 04:30:56 PM »
Thanx for the replies!
Jims99
Ormond Beach Fl.
« Reply #4 on: May 19, 2022, 05:36:18 AM »
To eliminate the 97-99 the Temperature Indicator Unit and
change to the later Thermostatic Switch do the following.
1, Replace the Thermo Sensor in the Thermostat Housing with
the later Thermostatic Switch (item #9, part # 37760-MAV-003
on the parts fiche). You will probably have to change the
connector on the end of the wire to match the new part.
2. Remove the Left Side Cover, the Coolant Tank, and
disconnect the Temperature Indicator Unit (item #16 on the
parts fiche).
3. Jumper the Green/Blue wire on the 2P connector to the Lt
Green/Black wire in the 4P connector.
4. The old Temperature Indicator Unit is no longer needed.
97 - 99 Valkyrie Std/Tourer
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
