November 11, 2025, 08:38:17 PM
Running on 3 cylinders
Topic: Running on 3 cylinders (Read 1821 times)
eRaGoN
May 25, 2022, 11:16:24 AM »
Bought a non running I/S due to gas tank corrosion..cleaned tank and replaced petcock. did carb overhaul and got it running for about 50 miles. has compression and spark on all cylinders but for some reason cylinder 1-3-5 stop working. Did I miss something here...totally run out of diagnostic ideas....help
Valker
Wahoo!!!!
Texas Panhandle
Re: Running on 3 cylinders
May 25, 2022, 11:55:50 AM »
Check fuel flow. Since it's one side, I suspect a plugged line.
Pappy!
Central Florida - Eustis
May 25, 2022, 06:32:16 PM »
Or there was more debris in the tank or the pilot passageways did not get properly cleaned.
What is your initial setting on the pilot needles? Turn them out to around 2.5 turns just for reference and see if that brings the cylinders back in.
Are they running on the mains when accelerating?
eRaGoN
July 25, 2022, 01:41:15 PM »
was set @ 2.5 turn...will pull the tank again and reseal it this time...might have to change all the jets on the carbs this time around.
=> InZane XXV
