February 12, 2026, 03:01:22 AM *
Author Topic: rear brake reassembly for final drive change  (Read 1792 times)
« on: June 05, 2022, 05:23:17 AM »
I know
I took something off I should not have
The bolt holding the brakes together
Now I cant get the pads onto the assembly to put the bike together
can someone send me a step by step
The pads are hanging by just the one side   They are good and clean but Gman is comin over and we must get this bike back together
« Reply #1 on: June 05, 2022, 06:04:10 AM »
OSS. First remove the pads completely. Next compress the pistons after cleaning them well. Third, re assemble the caliper on the plate without the pads. Make sure both spring plates are in place. Last install the new pads
« Reply #2 on: June 05, 2022, 09:00:20 AM »
It is together. And she runs
Axle in
Compressed  caliper
Pin in caliper
Funny  thing forgot shock
Don't look right
Duh
Now shocks on took her for a short ride
Monday or Tuesday will get front tire installed then put bags back  on
Cutting it close
Could not have done it without Gman and I was wearing my big bf shirt for luck
Maybe at inzane someone cN check our brake work?
« Last Edit: June 05, 2022, 09:03:17 AM by Oss » Logged
baldo
Youbetcha
Cape Cod, MA
« Reply #3 on: June 05, 2022, 09:08:16 AM »
I did quite a bit of prep for Taos. I met my riding buddy just over the bridge at the Cape Cod Canal, about ten miles from my house. I told him I keep hearing a clunk when I use my back brake. On closer inspection, I saw the problem. When I installed the rear caliper, I neglected to put the bolt through the caliper assembly.  You know, the one that keeps it from rotating.....The bolt was there, it just wasn't doing much.
DOH.
« Reply #4 on: June 05, 2022, 10:50:20 AM »
Dude, aren't you an aircraft mechanic?
« Reply #5 on: June 05, 2022, 11:27:50 AM »
wow
One thing, I was not going to change the o ring in the final drive since the other two looked fine
(I changed em anyway) but decided why not?
The thing was broken in two pieces   Holy moly
 SURE glad I checked it
The red eye o rings look stronger than the honda ones
baldo
Youbetcha
Cape Cod, MA
« Reply #6 on: June 05, 2022, 12:49:35 PM »
Well, yeah...
It's not like it's a turbine or something....
0leman
Klamath Falls, Or
« Reply #7 on: June 06, 2022, 08:23:36 AM »
DOH.
Good thing your bolt was still there.   Lost mine, not sure why, took a week or so to get new one.  Not a bolt you can run down  to local hardware store to replace.
