March 22, 2026, 07:52:10 AM *
Author Topic: air Purifier, Whole House UV-C Light in Duct for HVAC AC  (Read 1072 times)
« on: July 19, 2022, 06:44:38 AM »
I know there were some that were interested in a UV light for their duct work for their house. But did not want to make a unit themselves. Just received this unit that looks pretty good, although I have not tried it yet, but pretty fool proof and inexpensive. Heck you could replace the whole unit every year for the price of the bulbs if anything went wrong and its easy to install.
72W BioShield air Purifier, Whole House UV-C Light in Duct for HVAC AC (air Conditioning)
Brand: Mammoth
4.2 out of 5 stars 69 ratings
$89.97
& FREE Returns
Get a $200 Gift Card: Pay $0.00 $89.97 upon approval for the Amazon Prime Rewards Visa Card. No annual fee.
    ON Indiciator Light- LED on device to signal if UV-C light bulb is functional or not without having to remove the UV light system to check.
    Included Installation Template & All Parts- Designed for HVAC furnace AC Duct work, the light air UV purifier comes with installation template sticker, metal screws, and rubber grommet for an airtight seal.
    2 UV Lamp 36W Bulbs Included- Rated at 8,000 hours each (continues use. Switching device on & off will reduce the lifespan of the bulbs. Replacement bulbs available.
    TRUSTED SAFETY CERTIFICATIONS: CE, RoHS, FCC + 1 Year Hassle-Free Warranty
https://www.amazon.com/dp/B08JH9LRFQ?_encoding=UTF8&psc=1&ref_=cm_sw_r_cp_ud_dp_36AN86P3AH2MBP690QCM
« Reply #1 on: July 19, 2022, 10:35:58 AM »
You need more than just a UV light. Read up on Reme Halo. It’s a bit more expensive but well worth it.
« Reply #2 on: July 19, 2022, 03:25:49 PM »
Kinda  forgot about this. I put a light in the cold air return.
To  get our water  in NY to pass inspection for the sale, I ended up installing a UV light. This state now allows no bacteria at all. How can any water  supply have no bacteria.
« Reply #3 on: July 19, 2022, 06:21:24 PM »
Not really, UV light destroys the dna of the bacteria so it cannot reproduce. It also oxidizes smoke odors and most other cooking odors. I would also point out that the concentration of Hydrogen peroxide needed would be alot higher and needs more quantity and concentration to be effective. Peroxide also needs to be in contact with what ever it is disinfecting, UV light just needs to be in the proper intensity and it will hit everything that passes by it.
IF what you say were true then UV light for water sterilization in pools and water supplies would need to have the technology you talk about. Clean rooms in hospitals have only UV lighting as some may have a reaction to hydrogen peroxide.
I can see the benefits of what you are talking about though.
Odor control
Oxidizes hydrogen sulfide, mercaptans, amines and aldehydes. Hydrogen peroxide may be applied directly to aqueous wastes containing these odorants, or to wet scrubbers used to remove them from airstreams. If the odors are the result of biological activity, H2O2 may instead be added as a preventative to eliminate the anoxic conditions which favor the generation of odors.
https://www.h2o2.com/products-and-services/us-peroxide-technologies.aspx?pid=112
t-man403
Valk-a-maniac
Calgary, Alberta, Canada.
« Reply #4 on: July 20, 2022, 07:45:30 AM »
There are UV lights and then there is UV technology used for specific purposes. Also, like anything, there is always somebody trying to make something better, enhancing the effectiveness of the bulb. Cost is a factor. Some bulbs last a year while others last 2 and 3 years.  Anyway, this is what I have in my system.
https://www.freshaireuv.com/apco-x/
The short vid breaks it down for you.
« Reply #5 on: July 20, 2022, 11:58:58 AM »
Thanks.  I am building a file (just started with this post) of things I need to address when I replace my HVAC system (maybe next five or so years, not sure).
I did not watch its installation (new house, I built the house) but should have.  I don't remember if I identified the location for the unit but its location is sort of away for outside access (meaning replacing big parts takes time).
I don't know the status of the ducts, they are flexible and corrugated and I think probably have significant "stuff" in them but don't have a clue how to clean them.  Hence the need for something like the UV air purifier, particularly as we get older.
