November 11, 2025, 08:27:01 PM *
Author Topic: Orange hose help!  (Read 1792 times)
Unlaoised
Ireland
« on: July 23, 2022, 11:52:47 AM »
Just finishing the desmog and Dan marc fuel shutoff valve install and this brown/orange hose fell down onto the floor.
Where does it go?
« Reply #1 on: July 23, 2022, 01:27:13 PM »
drool tube from the bottom of air box. should be a black plug installed at the end with clamp.
https://www.valkyrieriders.com/shoptalk/bongobreather.htm
Unlaoised
Ireland
« Reply #2 on: July 23, 2022, 02:00:33 PM »
Ain't the drool tube, I just checked that and it's still there...
« Reply #3 on: July 23, 2022, 02:35:53 PM »
It looks like the drool tube with the oily blowby color and the exact same wire clamp for the plug.
Could it have been changed and the old one left in there?
Avanti
Stoughton, Wisconsin
« Reply #4 on: July 23, 2022, 03:12:14 PM »
Is that the old fuel line?  It looks like it has had a clamp on each end.
Speedy Coop
South Wales, New York
« Reply #5 on: July 23, 2022, 03:39:33 PM »
That looks identical to the drool tube on my '99.  Just checked to verify.
RonW
Newport Beach
« Reply #6 on: July 23, 2022, 05:48:20 PM »
doesn't have an oem style clamp (for the plug) if that's an indication.
« Last Edit: July 24, 2022, 07:55:04 PM by RonW » Logged
2000 Valkyrie Tourer
« Reply #7 on: July 23, 2022, 05:59:53 PM »
I wasn't talking about the radiator clamp but you're right, the spring clamp on bottom is not OE (your pic is).
RonW
Newport Beach
« Reply #8 on: July 23, 2022, 10:27:45 PM »
Jess, that's a micro worm gear clamp (1/4" - 5/8"). btw you done good detective work.
« Last Edit: July 23, 2022, 10:47:31 PM by RonW » Logged
Unlaoised
Ireland
« Reply #9 on: July 24, 2022, 02:28:04 AM »
Ok, mystery solved.
It is the drool tube, but its the other end of it, the end that connects to the air box. It goes from the air box to a connector that the capped drool tube is connected to.
Thanks all...
