February 11, 2026, 11:37:35 PM
Alternator Question
Topic: Alternator Question (Read 1706 times)
MotoBob
Alternator Question
August 25, 2022, 03:19:17 AM »
Picked up a 40 amp alternator from DB Electric recently. It does not appear to have a turn on speed until about 1200 rpms and registers 39 amps at 2400 rpms, and 40 amps at 2500. I believe the Valkyrie manuel states the OEM turn on is between 800 - 1000 rpms. I'm not seeing any of this as an issue since I'm not running anything other than the standard lighting although wanted know if anyone saw it differently.
Re: Alternator Question
August 25, 2022, 07:46:35 AM »
I have an after market high output (LActrical, I think) alternator in Ruby that doesn't kick on until around 1200 or so. It does reach 14.4 when charging. No issues have arisen from it. I try not to let the bike idle for long periods of time.
Grandpot
Fort Mill, South Carolina
August 25, 2022, 09:54:05 AM »
With the high rpm alternator, you will have a problem with the battery dieing if stuck in traffic and the fans turn on. You will need to keep the rpm up when standing still. I learned this the hard way.
Experience is recognizing the same mistake every time you make it.
WintrSol
Florissant, MO
August 25, 2022, 10:37:36 AM »
Which, for me, begs the question: how does the alternator know what rpm the engine is turning. Does the control circuit inside actually measure the cycles of the stator, with a minimal current through the rotor?
Steel cowboy
Spring Hill, Fl.
August 25, 2022, 11:22:45 AM »
My alternator will start to charge at 1200 rpm’s, once it’s charging it will still charge at 1000.
2001 black interstate
2003 Jupiter Orange wing
