November 07, 2025, 06:33:38 AM
Clutch fibers and steels
Topic: Clutch fibers and steels (Read 1015 times)
jdp
September 13, 2022, 06:09:15 PM »
Where is the best place to get clutch plates from fibers and steels
Re: Clutch fibers and steels
September 13, 2022, 06:17:01 PM »
I got OEM clutch discs from ProCaliber. You likely don’t need the steel plates. Did you have the dreaded rivet plate issue ?
September 13, 2022, 07:04:42 PM »
https://www.rockymountainatvmc.com/oem-parts/Honda
MAD6Gun
New Haven IN
September 14, 2022, 05:15:35 AM »
I did a clutch on my step-son's IS last year I got the parts from Ron Ayres Motor sports in NC. Lowest price I found. I think the price was around $240 for all the frictions,all the steals and the spring. I didn't replace the rivit plate. If your rivit plate is broken you most likely will NOT need the steels but if yours was slipping like my Step-son's was you will want to. Several of his steels were blue from the heat. I also replaced the spring. Just because.
jdp
September 15, 2022, 03:34:31 AM »
Thank you
pais
One more turn should do it!
Kent, Ohio
September 16, 2022, 02:19:45 PM »
How difficult of a job is this? I have never messed with a clutch before other than to pull it in to shift gears. Clutch just doesn't feel right.
Roadog
Reply #6 on:
September 23, 2022, 11:37:45 AM »
I sandblast the steels when ever I have the clutch down for service ,on any of my bikes.That cleans them up and will increase the 'holding' power of the clutch . My dragbike's clutch never slipped after doing this . If you have a clutch slippage issue, I highly recommend this, it will absolutely STOP any slipping . Check the steel plates for warpage on a FLAT surface , if they pass then blast them and reinstall. As for the friction plates , measure the thickness with a dial caliper and if it is within spec they are good to reuse.
Ride Safe
Roadog
=> InZane XXV
