February 12, 2026, 01:14:00 AM *
Author Topic: positive cable broke at battery  (Read 1723 times)
« on: September 25, 2022, 10:02:14 AM »
Ordered a replacement
How in the world do I access the other end of it?
Do I have to take off the tank?
If I could get the battery box out would I be able to see where the other end goes
Imagining it goes to the starter but that is just a guess
« Reply #1 on: September 25, 2022, 10:32:49 AM »
The battery cable has two other ends. One other end hooks onto that green
relay that you read about melting sometimes. The other other end goes to...
I'm not sure... my guess is the starter, but... someone knows... it is probably hard
remove the battery box...
« Last Edit: September 25, 2022, 11:31:28 AM by hubcapsc » Logged
RonW
Newport Beach
« Reply #2 on: September 25, 2022, 10:43:36 AM »
Between the battery positive(+) and the starter motor, there's the intermediary starter relay. The *other end* of the battery cable bolts onto the B post on the starter relay (B=battery). Take a pic of the old wire routing in case it's needed. Note orientation of the connector.
[edit] true dat, hubcapsc, the second starter motor cable goes from the starter relay's M post to the starter motor. (bottom pic., M=motor)
Pressing the start button energizes an electromagnet switch in the starter relay that internally bridges the relay's B post and the relay's M post allowing electricity to flow from the battery to the starter motor.
« Last Edit: October 05, 2022, 07:53:05 PM by RonW » Logged
2000 Valkyrie Tourer
« Reply #3 on: September 25, 2022, 04:50:49 PM »
The battery box is not that hard to remove. I have done it just to clean it
« Last Edit: September 25, 2022, 05:26:52 PM by Chrisj CMA » Logged
baldo
Youbetcha
Cape Cod, MA
« Reply #4 on: September 25, 2022, 05:40:40 PM »
Of course you have..... Wink Wink
« Reply #5 on: September 25, 2022, 06:35:10 PM »
It was the only way to get all the road grime off.
