Jim500
« on: October 06, 2022, 08:02:17 PM » |
My 97 valk has, out of nowhere developed a noise at the clutch ,or sounds like the clutch. The other thing is, the clutch lever will not pull in all the way. When I pull the clutch lever I get the noise. This just happened today. Thank You for any and all information.
« Reply #1 on: October 06, 2022, 08:16:22 PM » |
Sounds like some of the rivets gave way on the damper plate.
Jim500
« Reply #2 on: October 07, 2022, 09:22:27 AM » |
Do I need to replace the clutch?
Valker
Wahoo!!!!
Texas Panhandle
« Reply #3 on: October 07, 2022, 09:57:24 AM » |
If the rivets are sheared, yes. It is not too hard to do. If you have a shop do it, it's not TOO expensive if they're a good shop. My friend had it done at a dealer for less than $500.
Big Rig
« Reply #4 on: October 11, 2022, 12:25:06 PM » |
Had mine down two years ago...at the dealer...I think I paid around 7 hundred....but was leaving for a 4 day ride the next day....and well work...
Big Rig
« Reply #5 on: October 11, 2022, 12:29:15 PM » |
New problem....no clutch to engage gears....
New fluids, bled and nodda....I know there could be a possible lingering bubble in there, but after 4 days of bleeding, what am I missing?
99 interstate....
Jruby38
« Reply #6 on: October 11, 2022, 01:37:07 PM » |
You have to bleed the clutch from the bottom up with a horse syringe from Agway.
Big Rig
« Reply #7 on: October 21, 2022, 10:24:45 AM » |
Could not find horse syringe, so lots of patience....
Speedy Coop
« Reply #8 on: October 21, 2022, 10:38:32 AM » |
Try bleeding at the banjo bolt on the master. I bled mine from the bottom with a Mighty Vac pump. The only bike I ever reversed bled was my Concours 14.
Big Rig
« Reply #9 on: October 24, 2022, 05:49:42 AM » |
That was where the bubble was...at the banjo...disconnected from master, reconnected and added fluid and 5 minutes later....fully operational... Got our for a 2 hour test ride Friday afternoon....
Valker
Wahoo!!!!
Texas Panhandle
« Reply #10 on: October 24, 2022, 06:49:34 AM » |
