Bagger John - #3785
« on: October 08, 2022, 11:28:06 AM » |
P/N 17210-MZ0-000 Does ANYONE have these in stock? I've had at least two orders canceled today ...
« Reply #1 on: October 08, 2022, 12:19:23 PM » |
« Last Edit: October 10, 2022, 01:33:10 PM by 98valk »
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: October 08, 2022, 12:32:43 PM » |
I have one or two OEMs in my stash as well as two K&Ns. I’m good for the foreseeable future. RonAYERS.com is showing new ones for $18.35
« Last Edit: October 08, 2022, 12:35:12 PM by Valker »
« Reply #3 on: October 08, 2022, 01:00:52 PM » |
13.40 shipping (yikes) for me
turtle254
« Reply #4 on: October 08, 2022, 03:07:26 PM » |
heat shield mod .... whats that ?
« Reply #5 on: October 08, 2022, 03:52:40 PM » |
I will post about that later on in a separate thread after I finish. thanks
turtle254
« Reply #6 on: October 08, 2022, 04:10:11 PM » |
I will post about that later on in a separate thread after I finish. thanks Looking forward to that.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #7 on: October 08, 2022, 04:27:05 PM » |
13.40 shipping (yikes) for me They are my "go to" store. I always order enough to get free shipping.
« Reply #8 on: October 08, 2022, 05:36:50 PM » |
13.40 shipping (yikes) for me They are my "go to" store. I always order enough to get free shipping. why I like rockymountainatv.com only have to buy $75 to get free shipping vs $129 for ronayers and they have a RM Cash back program.
Ramie
« Reply #9 on: October 09, 2022, 09:55:04 AM » |
“I am not a courageous person by nature. I have simply discovered that, at certain key moments in this life, you must find courage in yourself, in order to move forward and live. It is like a muscle and it must be exercised, first a little, and then more and more. A deep breath and a leap.”
ckahler
« Reply #10 on: October 09, 2022, 09:37:47 PM » |
mine 28k miles zero difference in air flow from a brand new oem.
I did a test yrs ago with a 26k mile one vs new with a spare air box I have, a left blower and a CFM meter. zero difference btwn both.
this time, two days ago, I put both filters on bench top, used a shop vac and put the hose near the end of the filter and tried picking up the filters. used 28k filter picked up no problem, new oem picked up no problem. so then moved hose suction end closer to center incrementally and both filters were picked up exactly the same distance from the end. so all this indicates a used OEM filter with almost 30k miles on it is flowing exactly the same as a brand new OEM filter.
I have done simular shop vac testing using a vacuum meter. I got no pressure differance between new and a used filter blown out with compressed air. I regulary clean my air cleaners, but don't replace them unless they are damaged. different type of test, easier to do than the first one but the results were exactly the same. Then I have a SAE air filter report that clearly proved a filter with some miles on it is actually stopping harmful particles from entering better than a brand new filter. There is a SAE report for oil filters also indicating the same esp if one is doing shortened oil change intervals. it was based on the 3k mile oil change. using the same filter actually reduced engine wear.
Now I don't ride on dusty dirt roads every day and/or a lot of construction site areas which would shorten filter life. YMMV
if u really need one I have one new Hiflofiltro HFA1913 filter I could sell you. I have a new open one that I need to test for airflow vs OEM.
[/quote]
98 Valkyrie 85 V65 Magna 85 VT500c Shadow 81 KZ305
h13man
Indiana NW Central Flatlands
« Reply #11 on: October 10, 2022, 07:18:33 AM » |
Bagger John - #3785
« Reply #12 on: October 10, 2022, 10:13:57 AM » |
Are these in stock at Service? Several vendors have shown the filters to be available but have canceled my orders shortly after I've placed them.
h13man
« Reply #13 on: October 11, 2022, 06:32:12 AM » |
If they say so I assume they are. Never had any issue in the past but... Call them and see.
Joe333x
« Reply #14 on: November 03, 2023, 08:50:06 PM » |
Anyone use the Emgo filters? I cant seen to find any one with OEM instock. Theres these two on Amazon. Emgo Replacement Air Filter for Honda GL1500 Valkyrie 96-03 https://a.co/d/fawQIdPReplacement Air Filter for Honda GL1500 (VALKYRIE) 1988-2003 https://a.co/d/gHDecLm
« Reply #15 on: November 04, 2023, 05:05:33 AM » |
I got the hiflo one from amazon not long ago. I haven't installed it yet, but it looks "normal". Until OEM becomes available, the amazon ones will have to do...
« Reply #16 on: November 04, 2023, 07:30:12 AM » |
"While the maintenance schedule on most vehicles gives a mileage interval that’s commonly between 30,000 and 45,000 miles (though there may be a time interval as well) for air-filter replacement, many also include a shorter mileage interval for “severe service.” That’s usually described as regular driving in heavy traffic during hot weather, on unpaved roads or in dusty conditions." https://www.cars.com/articles/how-often-should-you-change-the-engine-air-filter-1420663059324/
Pluggy
« Reply #17 on: November 04, 2023, 07:39:03 PM » |
Anyone use the Emgo filters? I cant seen to find any one with OEM instock. Theres these two on Amazon. Emgo Replacement Air Filter for Honda GL1500 Valkyrie 96-03 https://a.co/d/fawQIdPReplacement Air Filter for Honda GL1500 (VALKYRIE) 1988-2003 https://a.co/d/gHDecLmI use Emgo air filters on Valkyrie . Also use Emgo products on my 1980 Honda as OEM has not been available for many years. Everything Emgo has fit and worked well.
Joe333x
« Reply #18 on: November 04, 2023, 09:27:31 PM » |
Anyone use the Emgo filters? I cant seen to find any one with OEM instock. Theres these two on Amazon. Emgo Replacement Air Filter for Honda GL1500 Valkyrie 96-03 https://a.co/d/fawQIdPReplacement Air Filter for Honda GL1500 (VALKYRIE) 1988-2003 https://a.co/d/gHDecLmI use Emgo air filters on Valkyrie . Also use Emgo products on my 1980 Honda as OEM has not been available for many years. Everything Emgo has fit and worked well. Thanks! I just ordered one from Amazon
