November 11, 2025, 06:22:09 PM *
Author Topic: 98 Valkrie Cheap carb rebuild kits  (Read 3043 times)
ckahler
Glen Allen, VA
« on: October 15, 2022, 06:11:32 PM »
https://www.ebay.com/itm/294939915318
6 bowl gaskets cost around $100. So at $26. for 6 entire rebuild kit, this seems like a steal.
4 of my carburetors are leaking around the bowl gaskets. The plan is to throw out most the other stuff and just use the gaskets. Has anyone tried the gaskets from these kits?
98 Valkyrie
85 V65 Magna
85 VT500c Shadow
81 KZ305
« Reply #1 on: October 15, 2022, 08:14:39 PM »
Made in China, that's all I need to know to pass on them. Rebuild kits are too critical to take a chance on quality.
« Reply #2 on: October 15, 2022, 10:20:42 PM »
Are you sure it’s the float bowls that are leaking ? It’s much more common for the leaking to be from the fuel rail o-rings.
« Reply #3 on: October 16, 2022, 03:31:15 AM »
Verifying that your post made it through to the board from
Your chinese computer  cooldude
« Reply #4 on: October 16, 2022, 05:53:27 AM »
ZING!  Grin
Bagger John - #3785
« Reply #5 on: October 16, 2022, 07:55:46 AM »
Is Redeye still doing carb kits?
I need to rebuild a spare 49-state set I have and swap the CA parts on my Tourer for them.
Timbo1
Tulsa, Ok.
« Reply #6 on: October 16, 2022, 10:19:38 AM »
I tried some Ebay rebuild kits a couple years ago and were just a big waste of time.  Nothing was right, there was like 1 o-ring that I could have used.  Don't waste your time & money get an All Balls rebuild kit or many recommend Redeye if you can get in touch with them.
ETA:
The All Balls kits have worked well for me and a complete rebuild kit including fuel rail o-rings can be had for about $110.
https://www.amazon.com/All-Balls-Carburetor-1997-2000-1998-2000/dp/B07DFPFV54/ref=sr_1_3?crid=3ICBPJISF5RGB&keywords=all+balls+rebuild+kit+valkyrie&qid=1665940892&sprefix=all+balls+rebuild+kit+valkyrie%2Caps%2C94&sr=8-3&ufe=app_do%3Aamzn1.fos.f5122f16-c3e8-4386-bf32-63e904010ad0
« Last Edit: October 16, 2022, 10:27:08 AM by Timbo1 » Logged
Savage
United States
« Reply #7 on: October 16, 2022, 10:34:12 AM »
I have contemplated doing the same a number of times "just to see."
I have refrained from doing so because taking the carburetors out, disassembling, cleaning, rebuilding, reassembling, then reinstalling is already enough of a pain in the butt.  I don't need to do it twice just to confirm that I wasted $20 to save $90 and should have bought the already-proven All Balls or Redeye components.
Columbia, South Carolina
Bagger John - #3785
« Reply #8 on: October 17, 2022, 01:55:41 PM »
I know many here diss All Balls fork seal kits - but are their carb components GTG?
h13man
Indiana NW Central Flatlands
« Reply #9 on: October 18, 2022, 07:16:59 AM »
Their wheel bearings are pretty low rent from my experience on the 1600 Vulcan I owned 3 yrs. ago but....
ckahler
Glen Allen, VA
« Reply #10 on: October 18, 2022, 09:58:37 AM »
I tested for leaks again, and the fuel rail o-rings are leaking. Maybe fuel running down from there is making it look as though the bowl gaskets are leaking. I hate buying complete rebuild kits, when all I need is a few o-rings. I usualy get my o-rings from the oring store, but I'm having trouble finding somewhere that lists the size. Any one know the size of those o-rings?
98 Valkyrie
85 V65 Magna
85 VT500c Shadow
81 KZ305
Timbo1
Tulsa, Ok.
« Reply #11 on: October 18, 2022, 10:50:11 AM »
You might send rug_burn a pm, seems he posted new sizes at one but I cant seem to find that post.
But here's the sizes I've used and so far so good after a couple years.
https://www.valkyrieforum.com/bbs/index.php/topic,114745.msg1159076.html#msg1159076
Jims99
Ormond Beach Fl.
« Reply #12 on: October 19, 2022, 05:02:59 AM »
These are the ones I ordered from the O-rings and more, they were listed as the upgrade to oem.
FKM o-ring 6x 1.5mm  and  FKM o-ring 7.8x 1.9mm jis p8
Ones the fuel rail the others the vent rails.
« Last Edit: October 19, 2022, 05:11:55 AM by Jims99/00 » Logged
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
rug_burn
Brea, CA
« Reply #13 on: October 20, 2022, 10:47:50 AM »
Yes- those are the sizes and material, FKM being  the same thing as Viton, and they're usually called out as V1.9 x 7.8 etc; they go in pretty tight, but that's a good thing.
   Also, V1.0 x 3.0 for the mixture screw.
I got mine from The O-Ring Store-  get 'em all at the same time- o-rings are cheap, but shipping's expensive...
« Last Edit: October 20, 2022, 10:54:46 AM by rug_burn » Logged
...insert hip saying here..
« Reply #14 on: October 20, 2022, 12:00:44 PM »
tighten the end nuts of the carburetor thru bolts. usually 1/16" turn is all that is needed. they do come loose over the miles. I've had to tighten the left side once in 75k miles.
Racernick
« Reply #15 on: November 27, 2022, 07:06:05 PM »
We bought several 30 dollars kits from ebay but after what we have went thur i dont recommend them because 80% of the kit is useless. i recommend just buying gasket kits and using a sonic cleaner and cleaning everything and re use all the old jets and needles inside the slides, if you want to buy a kit i hear all balls kit is the way to go but i was told to use a better float needle which i just purchased on amazon for 35 buck it's the k & L ‎18-8955 float needles
all we used from ebay kit is gaskets for bowl and air box side, use the fuel air mixture screw, one bike we used the float needles and currently doing good but then i learned of the better ones, and we used the o rings for slide where the needle is held in other then that all the rest is unused
i just replaced all the O rings in the vapor rail and fuel rails also on the air cut valves these was all the o rings i purchased. i can't Rember if i used the 4.5 or the 4 x 1.5 on the air cut valves just ordered both to be safe since they was so cheap
FKM O-ring 6 x 1.5mm  Minimum 10 pcs   $0.090 VAPOR RAILS
32 × FKM O-ring 6 x 1.5mm Minimum 10 pcs
FKM O-ring 4 x 1.5mm Minimum 10 pcs   $0.080
24 × FKM O-ring 4 x 1.5mm Minimum 10 pcs
FKM O-ring 3 x 1mm Minimum 25 pcs   $0.100
48 × FKM O-ring 3 x 1mm Minimum 25 pcs
FKM O-ring 7.8 x 1.9mm JIS P8 Minimum 10 pcs   $0.170   FUEL RAIL
32 × FKM O-ring 7.8 x 1.9mm JIS P8 Minimum 10 pcs
FKM O-ring 4.5 x 1.5mm  JIS S5  Minimum 10 pcs   $0.080
24 × FKM O-ring 4.5 x 1.5mm JIS S5 Minimum 10 pcs
Subtotal:
$16.960
Shipping:
$6.500
Grand Total:
$23.460
https://www.oringsandmore.com/fkm-o-ring-7-8-x-1-9mm-jis-p8-minimum-10-pcs/
https://www.oringsandmore.com/fkm-o-ring-6-x-1-5mm-minimum-10-pcs/
https://www.oringsandmore.com/fkm-o-ring-3-x-1mm-minimum-25-pcs/
« Last Edit: November 27, 2022, 07:22:29 PM by Racernick » Logged
ckahler
Glen Allen, VA
« Reply #16 on: November 28, 2022, 11:27:12 AM »
Thanks for the o-ring list.
Since the only reason I will be pulling the carbs is to fix fuel leaks. I will skip the rebuild kits and just order o-rings. I will also dissasemble and clean the carbs, but expect to be able to reuse the origional parts.
98 Valkyrie
85 V65 Magna
85 VT500c Shadow
81 KZ305
Pluggy
Vass, NC
« Reply #17 on: November 28, 2022, 01:23:27 PM »
Subtotal:
$16.960
Shipping:
$6.500
Grand Total:
$23.460
Valuable information.  Can this be posted in Shop Talk?  O-rings and More provides quality items and the prices are quite reasonable.
