November 20, 2025, 05:53:53 PM *
Author Topic: Trailer Relay Isolation Package  (Read 2081 times)
Sodbuster
« on: January 24, 2010, 07:25:17 AM »
I need to hook up a trailer wiring harness to my bike and came across this. Looks to be a pretty clean package vs hooking up individual relays, fuses, etc.
Has anyone else gone this route and any comments pro/con ??
http://www.electricalconnection.com/wire-harnesses/hrns-trailer.htm
VRCC # 30938
clintsdivco
Independence, Mo
« Reply #1 on: January 24, 2010, 07:45:10 AM »
I went with a very similar setup to that when I added a trailer.  I liked the idea of running the power for all the extra lights directly off of the battery and through a fuse and relay only getting the signal from the existing wiring.
I have pulled a trailer with this system nearly 23,000 miles and have had no issues at all.
Clint
Retired, Own & Ride a Valkyrie, It doesn't get any better than this.
Sodbuster
« Reply #2 on: January 24, 2010, 12:14:02 PM »
Not that it matters but is your setup a 4-wire or a 5-wire ??
VRCC # 30938
junior
new hampshire
« Reply #3 on: January 24, 2010, 12:49:46 PM »
mine is a powered tail light converter made by valley part # 32250
clintsdivco
Independence, Mo
« Reply #4 on: January 24, 2010, 01:36:02 PM »
I actually have both 4-wire and 5-wire as I have two different trailers and I set the bike up so I could use either trailer.
Clint
« Last Edit: January 24, 2010, 01:37:52 PM by clintsdivco » Logged
« Reply #5 on: January 24, 2010, 03:32:48 PM »
If you have a 4 wire trailer: go to pep Boys and buy a Hoppys trailer converter. PT# 46255. I use these on both of my bikes(98 Valk/05 Wing). Power comes from the battery and relays are triggered from taillight wiring.
Sodbuster
« Reply #6 on: January 24, 2010, 03:36:45 PM »
My trailer is wired for 5 wires ....
VRCC # 30938
